Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Hill start assist
  1. #21
    Dec 2010
    Helensburgh
    AS pointed out above the auto hold switch needs to be alight for it to work and if the brake pressure is not high enough the motor will not switch off and the auto hold brake will not work. I usually brake very softly and more often than not it needs an extra shove on the brakes after stopping to activate the autohold and switch the motor off.
  2. #22
    May 2017
    Quote Originally Posted by Ozsko View Post
    Only if the ACC is activated and it came to a stop without using the brake pedal. If the stop is under 3 seconds the car will move off when the car in front moves off and will usually re-start the engine when the car in front of the car immediately in front begins to move. It does this by reflecting the radar off the road under the car in front. If the resume button on the steering wheel is used the car will re-start and move off when the car in front moves, the same will happen when the throttle is slightly pressed or the steering wheel moved slightly. I think there needs to be a clear difference understood, re-starting is the motor starting and not the car moving. All the above is dependent on the ACC having stopped the car with no input from the driver. I was stuck in an hour long traffic jam some time ago and learned all about it there.
    I wasn't talking about moving, discussion was about start/stop. I said engine restarts when the car in front moves (regardless of ACC being off)
  3. #23
    Dec 2010
    Helensburgh
    The engine does not re-start if ACC is not active.
