Originally Posted by Passat R36 Depends on the lance you use, just don’t use dirt blaster on the car Thanks for that tip. So I guess just use it with the wider spread from some distance away.
Originally Posted by vdubbed12 Mine might be an older model as well. It’s Aquatak 120 1500W I think. Good to know that there is no issues with sensors. Mine's the Aquatak 10 if the additional info is of any use to you. Had to go out to confirm.
Mines the aquaTak 130, 1885psi.
Originally Posted by PDMJO Mine's the Aquatak 10 if the additional info is of any use to you. Had to go out to confirm. Thanks for that again, 👍 it looks like it’s a 1450psi unit.
Originally Posted by Simonr23 Mines the aquaTak 130, 1885psi. Thanks for that. So mine’s in between yours and PDMJO’s in terms of psi. Will see how it works on new and old cars.
View Tag Cloud
Forum Rules
