I leave my headlight switch in the automatic mode all the time. Every time I go under a bridge in the daytime, the lights turned on and then off when I'm past the shadow cast by the bridge span. They seem to be too sensitive and should not be coming on so quickly for such a brief shadow over the vehicle.
My Golf had a way of adjusting the sensitivity of the head lights so that they did not come on too quickly, but I can't find any such setting on my Tiguan.
Does anyone know if there is an adjustment for the head light sensitivity (maybe similar to how you are just the brightness of the dashboard lights)? If coding is required, does anyone know which VCDS parameters must be adjusted?
