View Poll Results: Do you prefer Traffic Sign Recognition or Navigation Speed Limit
Voters
93. You may not vote on this poll
  • Traffic Sign Recognition
    24 25.81%
  • Speed Limit on the Navigation System
    7 7.53%
  • A combination of the two, which VAG doesn't allow in Australia.
    62 66.67%
Page 28 of 30 FirstFirst ... 182627282930 LastLast
Results 271 to 280 of 300
Thread: A guide to enable EU specific features for AU Spec Tiguans
  1. #271
    Aug 2018
    Vic
    Quote Originally Posted by Aus_fas View Post
    I enabled it following steps from this thread. However, fusion mode does not work so of no use as the system will show incorrect speed if no speed sign is detected. Unless fusion is enabled , it's useless IMO.
    Sent from my HTC U11 using Tapatalk
    Mine shows no speed sign if none is detected. Also goes blank after a while if you haven’t been past a sign recently on say a freeway.
    The only time I have had a false reading is when I went past a Woolies truck on the freeway which has a 90 sign on the back and it picked that up.
  2. #272
    Nov 2016
    canberra
    Quote Originally Posted by MartoWolfie View Post
    Did you get the speed limit back showing on gps infotainment when you reverted?
    There are few settings mentioned in the steps that are already selected. Make sure you don't you don't unselect those once you revert back.
    I was then able to get the speed signs back on info
  3. #273
    Dec 2018
    Perth
    Would you happen to know which setting were already selected? When I did it first time I used the app which was a mistake since I dont what setting the app done.
    OR
    If you cant remember is there any chance you could look through the code for the road sign detection and tell me what is enabled/disabled etc. in your car?
    Thanks
  4. #274
    Nov 2016
    canberra
    OR
    Thanks
    See attached
  5. #275
    Dec 2018
    Perth
    From the first picture all the code mentioned i reverted in reverse. Like deactivated byte 5 bit 2 in control unit 17 and so on. So everything i done was opposite to revert the road sign detection. I m just bit confused where you have byte 24 bit 6 crossed out in 5F. I deactivated it part of reverting. So should i leave it activated?
    Sorry for being a pain.
  6. #276
    Nov 2016
    canberra
    Leave it activated, its enabled by default.
  7. #277
    Please, could you write step by step because stay confusion the process. Best regards.
    Enviado de meu SM-G950F usando o Tapatalk
  8. #278
    Dec 2018
    Perth
    That makes sense. Thanks for your patience
  9. #279
    Aug 2018
    Hi all
    interesting thread and making me contemplate some of the simpler tweaks
    Just looking at the OBDeleven site (AU) and noticed this
    A link to download the OBDeleven application will be included with your purchase, and can be accessed via your purchase history or confirmation email. The OBDeleven Android App is NOT available on the Australian or New Zealand Google Play Stores.
    Do I need to access or download OBD app from another country’s google play store or does the link they provide give a version that works on Android?
    2018 Allspace 162TSI R Line
  10. #280
    Nov 2016
    canberra
    Quote Originally Posted by iDiesel View Post
    Hi all
    Interesting I didn't notice that the app is no longer available. I believe the link version should work as the one that I got from the store a year ago still works. All you need is the.apk file IMO.
