New project
Has anyone enabled the graphics for engine coolant and oil on their mib ?
Sent from my SM-G935F using Tapatalk
already enabled in mine
as I understand it’s a SWaP feature (dealer only activated (IF you can find a dealer that will/can do it))
but under module 5A, adaptions, car function adaptions gen 2, there is a menu_display_SportHMI, you could try setting that to activated (and also over_threshold_high of course)
Hi I have a Passat Alltrack 2017. It has the Luxury package which includes the led headlamps and drls. This also has dynamic cornering lights. Is it possible to enable light assist which is what I assume the feature to automate the high beams with the coding that NZ_GolfR provided. I am quite confused what the difference between light assist, dynamic light assist and high beam assist? Are they the same thing?
I am also looking to see if I can enable Adaptive Lane Guidance. Would this be the same coding as the Tiguan? I have the basic lane assist but I want the ALG until someone works out TJA.
I think high beam assist puts the high beam on when it doesn’t sense a incoming car or a car in front, whereas dynamic the high beams are on all the time but it has shutters in the headlights and if it senses a car in front it will dip straight ahead (but the sides will still be on high) and if a car is coming the other way it will dip both lights on the right side and both lights on the left side will stay on high beam
TJA has been worked out dude, it’s a VCP tweak and chargeable
