saveferris: Yes - I do see an issue! Try setting Byte_13_RDS to not_deactivated (yes, it's a double negative). Reset the MIB again and see what happens.
I have the same issue with mine. I have enabled it and most of the time the TMC sign has a line through it with no traffic info:
However occasionally when I look the TMC sign changes to have like a chain link behind it and I had 1 traffic report listed but this is Auckland and I'm certain there was more incidents than that!
I have done the same coding on a mate Skoda vRS and his works flawlessly. Just after I did his on a Friday afternoon he sent me a picture showing 24 Traffic Reports and mine had none at the same time.
I don't use the VW navigation much, prefer the Apple navigation personally just wish could get it on the AID and HUD, so haven't worried about looking into this issue too much. Might have to do some playing around and see what might be causing this.
Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
I just found this forum that mentioned a similar issue on an Audi A6 and there's was apparently fixed with a software update: TMC crossed out
I wonder if it is a software issue, just checked mine and this is what it is running:
I am running a Discover Pro in mine but maybe you can compare to yours and someone else that has theirs working properly could also compare as well. I will also try connecting my car to the WiFi later tonight and see if it can find any updates.
saveferris: hmm.... I've got just one last suggestion (below) but I'm fairly confident that the RDS setting should be activated (or, "not deactivated") because TMC information is transmitted over the Radio Data Service for the FM band. Byte 14 has a separate RDS switch -I don't know why this separate switch is needed!
If you haven't lost the previous FM radio settings when you reset the MIB and if you still aren't receiving TMC - then alas I'm really puzzled (especially since I have already enabled TMC on two Tiggys !
Does road sign detection work without Gps / navigation? (Tiguan -17)
Skickat från min SM-G950F via Tapatalk
