saveferris: When you say above "I reset the unit" - how did you do this? Did you use the factory reset facility in the MENU, or did you reset the entire MIB unit by pressing the ON/OFF button? Because the latter technique is required for this tweak.
I have done both...as you advised me in a previous post I held down the ON/OFF button till it turned off and let go once the logo had switched on.
I literally just did it again now, putting in the 1024 value in and then reset it by the ON/OFF button.....I'm obsessed in making this work
