It is a pity there is no explanation for each modification, half of them I don't understand what they do.
I'm planning to get OBD eleven... on their aussie suppliers website there are instructions for quite a few tweaks for MQB platform.
https://www.autoinstruct.com.au/manu...n-vcds-tweaks/
Does anyone on here has any experience with it? Any good?
Half (or almost) of them is implemented in stock configuration.
It doesn't work for me.
Steps I did as per this thread using OBDeleven
TMC Traffic
Go into Module 5F - Information Control Unit
Select Adaptations, select "Fee-based traffic information (TMC)
Set value from 65535 to 1024
Make sure you enable traffic information in the radio, and set RDS region to automatic.
I reset the unit. When I press traffic i have no new messages even in peak hour Melbourne traffic. with the little symbol at the top with a line through it.
I'm extremely jealous that i'm unable to get it to work.
When you go back into the module has it retained the 1024 setting?
If it has then it has to be a setting you haven't enabled in either the radio settings or settings within the traffic page itself.
Is this a discover pro you're trying this on?
Yes it has retained its setting, I even reverted back to the old setting and re-applied it again.
In the radio settings I have enabled TP Traffic program, Not sure there are any more settings in the Traffic page/button itself, I couldn't find any.
No I'm using the Discover Media audio and satellite navigation system on the 132 TSI Comfortline.
Ok, well if that's true then you must be doing something wrong. It does take a few minutes to get any data to show, don't expect anything immediately.
It's also dependent on FM reception so if you're not in an area with good FM Reception that may be an issue.
It's also only available in capital cites. If you're not in one it doesn't work.
