So I think I have managed to have some success here with activating this wit the R-Line LED lights. Here is what I have done (using OBDeleven):
Make sure Lights are switched off
Control Unit: Central Electronics (Hex09)
Adaption - Fernlicht_assistent - Menuesteuerung Fernlichtassistent: Change to Present
Adaption - Fernlicht_assistent - Erweiterte_Frenlichtsteuerung: Change to AFS, FLA, Fernlicht ueber AFS (mine was originally set to: AFS, Fernlicht ueber AFS) - This was the important change that wasn't documented anywhere else and seems to stop the rest of the coding from working.
Coding - Long Coding - Byte 2: Change to Hex3 (Bit 0=1, Bit 1=1)
Control Unit: Front Sensors Driver Assistance System (HexA5)
Coding - AFS_coding_Light_assist: Change to High_Beam_Assist (Long coding Byte 21 - Hex 20 (Bit 5=1))
Once I had done this I now have Light Assist showing in the Car Settings Menu under Light Settings:
![A guide to enable EU specific features for AU Spec Tiguans-light-assist-menu-jpg](https://www.vwwatercooled.com.au/forums/attachments/f238/29244d1493372622t-guide-enable-eu-specific-features-au-spec-tiguans-light-assist-menu-jpg?s=ad7837117c71f8e2c28b53b1cda3d081)
And when I flick the lights stalk forward I get the Light with A in it showing on the AID:
![A guide to enable EU specific features for AU Spec Tiguans-light-assist-aid-jpg](https://www.vwwatercooled.com.au/forums/attachments/f238/29245d1493372892t-guide-enable-eu-specific-features-au-spec-tiguans-light-assist-aid-jpg?s=ad7837117c71f8e2c28b53b1cda3d081)
Now I just need to test to see how it works...
Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
