View Poll Results: Do you prefer Traffic Sign Recognition or Navigation Speed Limit
Voters
93. You may not vote on this poll
  • Traffic Sign Recognition
    24 25.81%
  • Speed Limit on the Navigation System
    7 7.53%
  • A combination of the two, which VAG doesn't allow in Australia.
    62 66.67%
Page 5 of 30 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 300
Thread: A guide to enable EU specific features for AU Spec Tiguans
  1. #41
    Aug 2016
    Auckland, NZ
    Quote Originally Posted by peanut View Post
    Doesn't work. It's a shame since I think I might be getting warmer and warmer to enabling the Emergency and Traffic Jam Assist. If anyone else knows the SA for Module 13 that'll be great.
    EDIT: I can pretty much confirm that both of those features can be enabled via VCDS or OBDEleven. Just need the SA.
    Try using code 20103 (mine accepted this which is the same code as A5 - Front Sensors Driver Assistance System)
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
  2. #42
    Jan 2017
    Quote Originally Posted by NZ_GolfR View Post
    Thats the same code as the new Passat too. Check out this link: [V5] ProBoards - Free Forums & Free Message Boards I PM'd peanut this earlier as I didnt want to rock myself on here LOL
    MY18 Tiguan 162TSI, Deep Black Pearl, R-Line, Sunroof, DAP | Ordered 6th Jan 17 | Delivered Nov 17
  3. #43
    How did you find that? Can you show me how? Through VCDS or did you dismantle your headlight?
    Can't confirm from my car headlight. To many plastic covers and every with own part number.
    But just sitting in my garage with VCDS and doing scans of every module. Trough weekend I should get my friend car, where it is easier to mention what is not included in setup
  4. #44
    Ok, so after my evening with "zeros and ones", I can confirm that below is possible with Tig:
    - enabled needle sweep on Active Info Display
    - changed number of blinks in confort turn signals
    - enabled confirmation sound when open/close with option in menu
    - DRL on/off via media screen (when lights switch is in 0 position)
    All in "standard" way, but after coding if not immediately visible change, you need to make "factory reset" selected section of settings.
  5. #45
    Feb 2016
    Melbourne, Victoria
    Some updates:
    - SA 20103 worked for module 13.
    - Emergency Assist and Traffic Jam Assist requires long coding on several modules, by that I mean a lot of modules, including Modules 13, 17, 44, 5F, A5, 09.
    - Coding in Module 19 - CAN Gateway may be blocking coding to Pedestrian Assist, or we are missing a submodule.
    Also what is wrong with the coding for module 09 obtained from VCDS? All of the coding are composed of 0 bits???
    Coding for Module 44 - Steering Assist is also significantly different between Tiguans - I only see two bytes in mine, rather than 7 bytes compared to others.
  6. #46
    peanut, I've updated my thread on RT. All modules maps in last post.
  7. #47
    Oct 2016
    Quote Originally Posted by bestyjny View Post
    Where's that Besty? Are you talking about the Ross-Tech forums. I couldn't find much Tiguan related stuff there.
  8. #48
    Quote Originally Posted by IsDon View Post
    Here you go:
    2016 Tiguan MQB, 2.0 TSI 180KM CZPA
  9. #49
    Oct 2016
    Cool thanks mate.
  10. #50
    Aug 2016
    Auckland, NZ
    Hi peanut, do you mind letting me know how you coded the Adaptive Lane Guidance? I have changed the "Point_of_intervention" to "Early (settings via menu)" in module A5 but this doesn't seem to have fully worked. I now have the option to toggle Adaptive lane guidance in the Driver assistance setting in the Infotainment unit but I don't have the option for the Waring level:
    I am assuming there must be something extra that needs enabling that I have missed? Even though it is showing as turned on it doesn't appear to be working as the lane assistance still doesn't kick in until I get over ~65km/h and still pinballing in the lane.
    Also interested to know how you enabled Light Assist as well as I will like to try turning this on in my car as well.
    I will hopefully have a copy of all the module backups later today so will PM them to you as well.
    Cheers.
