View Poll Results: Do you prefer Traffic Sign Recognition or Navigation Speed Limit
Voters
93. You may not vote on this poll
  • Traffic Sign Recognition
    24 25.81%
  • Speed Limit on the Navigation System
    7 7.53%
  • A combination of the two, which VAG doesn't allow in Australia.
    62 66.67%
Results 1 to 10 of 300
Thread: A guide to enable EU specific features for AU Spec Tiguans
Threaded View
  1. #9
    Feb 2016
    Melbourne, Victoria
    Quote Originally Posted by NZ_GolfR View Post
    Just to give an update the coding for the Dynamic Road Sign Display works on NZ version of the Tiguan R Line (forgot to mention earlier that I didn't need to change Byte 24, Bit 6 in Module 5F as it was already activated).
    The only issue is that I don't get the road signs showing in the Heads Up Display, I do get the warning there if I go over the set speed limit though. I noticed that if I go into the Heads Up Display setting in the Car Setup screen there is no option to turn this on or off like the other features so I am guessing there is additional coding need to enable this. When I get a chance I will have a look at the modules and see what other adaptations there are to see if I can find this one to enable it.
    Oh yes, I forgot to include the instructions for enabling traffic signs on HUD because such spec doesn't exist in Australia.
    I will dig around to see how it can be enabled.
    EDIT: Try this, I compared coding with someone else. No guarantees that it will work because I haven't tried it.
    Module 82
    Coding
    Long Coding
    Byte 0, Activate Bit 0.
