This thread is fantastic!
Can anyone confirm that enabling Adaptive Lane Guidance works as expected, i.e. keeps the car in the centre of the lane, rather than 'bouncing' it off the lane markings (like Active Lane Assist)?
peanut: caution when doing tweaks is always wise -regardless of which MQB platform vehicle is being modified.
I've just been looking through the adaptation maps from VWVY's Tiggy (which he kindly allowed me to take this afternoon - many thanks again Victor). There appear to be many identical adaptation channels between the two models -so I suspect that there will be a degree of congruence with tweas from other MQB vehicles (including the mk7)
However, there are also many different adaptation channel descriptors, as you say. Whilst I'm sure that there will be entirely new channels in the newer modules, it appears in lots of cases where the changed names are superficial - so it's not difficult in these cases to "translate" the tweak instructions into Tiggy speak
Here's an example: For the mk7, the BCM has a channel name IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant whereas the Tiggy reports this channel as ENG10610-ENG126844-Front_wiper-Washer_Tipwiping_Variant.
I guess my message to would-be VCDS/VCP/OBD11 "tweakers" is certainly proceed with caution, but likewise, don't discount the wealth of established and now-mature instructions that resides on forums for other MQB models (like mk7 Golf). I'm also a fan of the advantage of making errors in the leaning curve - they are by far the very best learning experience!
It will be obvious which tweaks won't work because you just won't be able to find the adaptation channels -so you won't be able to proceed. Tweaks that require changes to a module's code string are a bit more problematic and these should be approached with more care. In general if you are using instructions from another model NEVER just rely on instructions like "Change Byte 2, Bit 0" - ALWAYS make sure that you have access to the Long coding helper screen from the other vehicle - and compare this Byte/Bit descriptor with that of the Tiggy
And most definitely, BEFORE YOU START making changes, create a complete database of the "virgin" settings in your car - the admaps from VWVY'S Tiggy this morning had well over 5,000 adaptation channels and the ABS module alone had a massive Byte count of 47 bytes - in just this module (incidentally, the ABS module on the MY17 mk7 has exactly the same Byte-count)
Guys, all of this features you mention I had in standard equipment.
- Lane Assist
- Light Assist
- Front Assist
- Emergency Assist
- Traffic Jam Assist
I paid extra for:
- Side Assist Plus
- Rear Traffic Alert
If I can help you, let me know what data you need.
I have limited access to VAS and VCDS, so it can take few days.
I put some on Ross-Tech forum:
2016 Tiguan MQB, 2.0 TSI 180KM CZPA
Hi Don, thanks for the thoughtful advice you provided. I'm more of an amateur than an experienced VCDS veteran like you.![]()
I believe that you are correct in your manner. e.g. personally I cannot find how to enable the DRL menu in my Tiguan because they changed the adaptation, but I know it definitely still exists.
Do you by any chance know the SA for Module 13? By gaining access to module 13, I believe this will allow us to enable Emergency Assist and Traffic Jam Assist, and hopefully Pedestrian Assist as well.
Just to give an update the coding for the Dynamic Road Sign Display works on NZ version of the Tiguan R Line (forgot to mention earlier that I didn't need to change Byte 24, Bit 6 in Module 5F as it was already activated).
The only issue is that I don't get the road signs showing in the Heads Up Display, I do get the warning there if I go over the set speed limit though. I noticed that if I go into the Heads Up Display setting in the Car Setup screen there is no option to turn this on or off like the other features so I am guessing there is additional coding need to enable this. When I get a chance I will have a look at the modules and see what other adaptations there are to see if I can find this one to enable it.
Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
Oh yes, I forgot to include the instructions for enabling traffic signs on HUD because such spec doesn't exist in Australia.
I will dig around to see how it can be enabled.
EDIT: Try this, I compared coding with someone else. No guarantees that it will work because I haven't tried it.
Module 82
Coding
Long Coding
Byte 0, Activate Bit 0.
No dramas, figured that the HUD settings wasn't important to you guys since you miss out on it (despite what everyone says I actually find it an awesome option that is really useful). I will have a dig around as well and let you know if I find anything so you can update the post.
