Thats the same code as the new Passat too. Check out this link: [V5] ProBoards - Free Forums & Free Message Boards I PM'd peanut this earlier as I didnt want to rock myself on here LOL
MY18 Tiguan 162TSI, Deep Black Pearl, R-Line, Sunroof, DAP | Ordered 6th Jan 17 | Delivered Nov 17
Ok, so after my evening with "zeros and ones", I can confirm that below is possible with Tig:
- enabled needle sweep on Active Info Display
- changed number of blinks in confort turn signals
- enabled confirmation sound when open/close with option in menu
- DRL on/off via media screen (when lights switch is in 0 position)
All in "standard" way, but after coding if not immediately visible change, you need to make "factory reset" selected section of settings.
Some updates:
- SA 20103 worked for module 13.
- Emergency Assist and Traffic Jam Assist requires long coding on several modules, by that I mean a lot of modules, including Modules 13, 17, 44, 5F, A5, 09.
- Coding in Module 19 - CAN Gateway may be blocking coding to Pedestrian Assist, or we are missing a submodule.
Also what is wrong with the coding for module 09 obtained from VCDS? All of the coding are composed of 0 bits???
Coding for Module 44 - Steering Assist is also significantly different between Tiguans - I only see two bytes in mine, rather than 7 bytes compared to others.
peanut, I've updated my thread on RT. All modules maps in last post.
Here you go:
2016 Tiguan MQB, 2.0 TSI 180KM CZPA
Hi peanut, do you mind letting me know how you coded the Adaptive Lane Guidance? I have changed the "Point_of_intervention" to "Early (settings via menu)" in module A5 but this doesn't seem to have fully worked. I now have the option to toggle Adaptive lane guidance in the Driver assistance setting in the Infotainment unit but I don't have the option for the Waring level:
I am assuming there must be something extra that needs enabling that I have missed? Even though it is showing as turned on it doesn't appear to be working as the lane assistance still doesn't kick in until I get over ~65km/h and still pinballing in the lane.
Also interested to know how you enabled Light Assist as well as I will like to try turning this on in my car as well.
I will hopefully have a copy of all the module backups later today so will PM them to you as well.
Cheers.
Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
