View Poll Results: Do you prefer Traffic Sign Recognition or Navigation Speed Limit
Voters
93. You may not vote on this poll
  • Traffic Sign Recognition
    24 25.81%
  • Speed Limit on the Navigation System
    7 7.53%
  • A combination of the two, which VAG doesn't allow in Australia.
    62 66.67%
Page 30 of 30 FirstFirst ... 20282930
Results 291 to 300 of 300
Thread: A guide to enable EU specific features for AU Spec Tiguans
  1. #291
    Pacific Paradise QLD
    Quote Originally Posted by iDiesel View Post
    V1 OBDeleven on sale at the moment $129
    I was checking to see if V2 version had arrived, but doesn't look like it yet
    I posted about the pre order in a thread two weeks ago and included the link in it.
    It isnt on the site that is selling htem for $129 as that is an Aussie site its was on obdeleven.com
    Here it is Voltas IT, LCC
  2. #292
    Aug 2018
    Other than iOS compatibility and maybe faster processing in the unit, is it worth getting the V2?
    At this stage I'm only thinking about modding some of the minor tweaks; stop/start, undertake on LHS, maybe traffic sign recognition and Traffic alerts.
    2018 Allspace 162TSI R Line
  3. #293
    Jun 2013
    Qld
    Honestly a little bit expensive for just a couple of tweaks.
    I bought the hex-net version an cannot even code mirrorlink in motion.
    I would be better of paying someone to do the tweaks.
    Sent from my SM-G965F using Tapatalk
  4. #294
    I have tried doing speed sign recognition and it doesnt work on mine.
    Did it with the APP and it said success but no signs ever appear Have rebooted unit and all but nothing
    The stop start wont turn off with the app in mine either Tried yesterday and says not applicable.
    Also headlight assist wont work either.
    Not as good as I thought it would be or maybe VW had introduced software to stop certain things as works in some earlier vehicles apparently
    Traffic alert works cant see the worth in LH passing as will only light up the warning in the mirror housing
    Having taillights on with DRL is more sensible and blinkers on with boot open
  5. #295
    Oct 2015
    Hillbilly, I have the steps printed out in my car for
    Traffic sign
    Stop start
    And a couple you haven’t mentioned.
    All work perfect. Have had to reenable a few of them each time it goes to vw for warranty work- as they reset the computer each time. Later on, I can write down my steps for you to try.
    Perhaps you’re right and the process is different/blocked(I doubt it’s blocked tbh)
    Edit- left hand passing should be an actual slowing of the car when on cruise control- annoying and dangerous, not just light in the mirror.
    Stop start gives no sign of it working, until you are in a position where it wants to turn the car off- and it won’t. You just get the little status icon/message on the display. I believe it ups the voltage required to enable stop/start, to a voltage that isn’t attainable.
  6. #296
    Aug 2018
    Quote Originally Posted by Simonr23 View Post
    This is one I definitely want as I cruise u and down the freeway between Sydney and Central Coast and often have idiots doing 90-100 in the fast lane, while I sit on 110km/hr in the middle...
  7. #297
    Traffic sign
    Stop start
    Have been out and tried a few things
    Stop/start says not supported
    Traffic sign recognition says it did it but no signs show up
    Headlight washers activate but dont think car has them
    Battery level activates but on pressing button it just goes from Time to Copyright and a 100page rant about the software.
    Vibration on Lane assist is in the MIB but only gives option of on or off. Not adjustable as app intimates.
  8. #298
    Where possible it's advisable to use manual coding/adaptation as you can easily reverse what you've done.
    The apps change potentially multiple things and you can't easily undo them
    Some things like vim change things that aren't simple adaptation/coding so are the only way to activate.
  9. #299
    Feb 2019
    Perth, WA
    MY19 Highline with R-Line+S&V
    Same deal with mine when using the built in apps... OBD11 app says Traffic Sign Recognition isn't support on my car (could be the new AID triggering that?) Car doesn't have headlight washers and I haven't been confident enough to try the others. I will when I can work out how to "backup" the factory coding using ODB11.
  10. #300
    Quote Originally Posted by phonebooth View Post
    Mine has the'Old" aid
    Am going to try to code them tomorrow
    Will write down the settings before I alter them
    Want to do the Headlight assist but dont know if I have the "good" versions to do it
    Here are the pages from ERWIN on whats in my car
    Got it to do the 'Turn off Stop Start' but wouldnt do High Beam Light Assist
    Attached Thumbnails Attached Thumbnails A guide to enable EU specific features for AU Spec Tiguans-004_our-tiguan-full-data-jpg   A guide to enable EU specific features for AU Spec Tiguans-005_our-tiguan-full-data-jpg
    A guide to enable EU specific features for AU Spec Tiguans-007_our-tiguan-full-data-jpg   A guide to enable EU specific features for AU Spec Tiguans-008_our-tiguan-full-data-jpg
