View Poll Results: Do you prefer Traffic Sign Recognition or Navigation Speed Limit
Voters
93. You may not vote on this poll
  • Traffic Sign Recognition
    24 25.81%
  • Speed Limit on the Navigation System
    7 7.53%
  • A combination of the two, which VAG doesn't allow in Australia.
    62 66.67%
Page 23 of 30 FirstFirst ... 132122232425 ... LastLast
Results 221 to 230 of 300
Thread: A guide to enable EU specific features for AU Spec Tiguans
  1. #221
    saveferris: Yes - I do see an issue! Try setting Byte_13_RDS to not_deactivated (yes, it's a double negative). Reset the MIB again and see what happens.
  2. #222
    Mar 2009
    Just changed the setting to not_deactivated.
    I'll let you know tomorrow when I'm driving around if it's worked .
    Thanks you.
  3. #223
    Mar 2009
    Right now sitting in peak hour traffic been driving for 2 hours......still doesn't work I have TMC sign with a line through it
  4. #224
    Aug 2016
    Auckland, NZ
    Quote Originally Posted by saveferris View Post
    I have the same issue with mine. I have enabled it and most of the time the TMC sign has a line through it with no traffic info:
    However occasionally when I look the TMC sign changes to have like a chain link behind it and I had 1 traffic report listed but this is Auckland and I'm certain there was more incidents than that!
    I have done the same coding on a mate Skoda vRS and his works flawlessly. Just after I did his on a Friday afternoon he sent me a picture showing 24 Traffic Reports and mine had none at the same time.
    I don't use the VW navigation much, prefer the Apple navigation personally just wish could get it on the AID and HUD, so haven't worried about looking into this issue too much. Might have to do some playing around and see what might be causing this.
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
  5. #225
    Mar 2009
    Quote Originally Posted by NZ_GolfR View Post
    I've also had the chain link briefly but no report, I just don't get how some can get it and some cant with the same model.......surely somewhere down the line it has to be software issue/setting.
  6. #226
    Aug 2016
    Auckland, NZ
    Yes I think so but it is a bit hard to diagnose especially since it is supposed to be a service that you pay to have enabled so can't go back to the dealer to ask. Will let you know if I find anything.
  7. #227
    Aug 2016
    Auckland, NZ
    I just found this forum that mentioned a similar issue on an Audi A6 and there's was apparently fixed with a software update: TMC crossed out
    I wonder if it is a software issue, just checked mine and this is what it is running:
    I am running a Discover Pro in mine but maybe you can compare to yours and someone else that has theirs working properly could also compare as well. I will also try connecting my car to the WiFi later tonight and see if it can find any updates.
  8. #228
    saveferris: hmm.... I've got just one last suggestion (below) but I'm fairly confident that the RDS setting should be activated (or, "not deactivated") because TMC information is transmitted over the Radio Data Service for the FM band. Byte 14 has a separate RDS switch -I don't know why this separate switch is needed!
    If you haven't lost the previous FM radio settings when you reset the MIB and if you still aren't receiving TMC - then alas I'm really puzzled (especially since I have already enabled TMC on two Tiggys !
  9. #229
    May 2017
    Sweden
    Does road sign detection work without Gps / navigation? (Tiguan -17)
    Skickat från min SM-G950F via Tapatalk
  10. #230
    Mar 2009
    Thanks DV52, I have the same setting in Byte 14. I do get all the RDS from the FM stations, song weather etc but Still No Traffic.
    I've been cheated lol.
