View Poll Results: Do you prefer Traffic Sign Recognition or Navigation Speed Limit
Voters
93. You may not vote on this poll
  • Traffic Sign Recognition
    24 25.81%
  • Speed Limit on the Navigation System
    7 7.53%
  • A combination of the two, which VAG doesn't allow in Australia.
    62 66.67%
Page 22 of 30 FirstFirst ... 122021222324 ... LastLast
Results 211 to 220 of 300
Thread: A guide to enable EU specific features for AU Spec Tiguans
  1. #211
    saveferris: When you say above "I reset the unit" - how did you do this? Did you use the factory reset facility in the MENU, or did you reset the entire MIB unit by pressing the ON/OFF button? Because the latter technique is required for this tweak.
  2. #212
    Mar 2009
    I have done both...as you advised me in a previous post I held down the ON/OFF button till it turned off and let go once the logo had switched on.
    I literally just did it again now, putting in the 1024 value in and then reset it by the ON/OFF button.....I'm obsessed in making this work
  3. #213
    saveferris: are these settings the same?
  4. #214
    Jan 2017
    Warrandyte
    Is there a obdeleven type device you can use with a apple device?
  5. #215
    Jun 2012
    Dee Why, NSW
    Quote Originally Posted by Tigger162 View Post
    I don't think there is. Seems like VCDS and OBDEleven are the only options. Maybe pick up a cheap Android phone or tablet off ebay? Should be able to find something for $40-$50.
    2017 Tiguan 162TSI Highline/R-Line
    2017 Audi S3
  6. #216
    Noob question, do these changes void warrant? Do I need to revert the changes before sending the car to be serviced?
    Sent from my Nexus 6P using Tapatalk
  7. #217
    Oct 2016
    Artarmon, NSW
    Blog Entries
    1
    No minor ECU changes do not void warrantee. Btw. VCDS only runs on Windows operating system not Android or Apple.
    Sent from my SM-G930F using Tapatalk
    Ordered: 2017 build date Tiguan 162 TSI Highline with DAP in Tungsten Silver and rear luggage tray. ETA: late April / Early May. I did not have to wait. I took delivery on 11 March 2017.
  8. #218
    Oct 2016
    Artarmon, NSW
    Blog Entries
    1
    Sorry above May be confusing. There should be a full stop after No.
  9. #219
    Quote Originally Posted by Delewin View Post
    Thank you.
  10. #220
    Mar 2009
    Byte 13_RDS: Not_deactivated vs deactivated.....can you see any issues with my settings ?
    Sorry the pics are so massive.........
    [IMG][/IMG] [IMG][/IMG]
    [IMG][/IMG] [IMG][/IMG][IMG][/IMG]
