View Poll Results: Do you prefer Traffic Sign Recognition or Navigation Speed Limit
Voters
93. You may not vote on this poll
  • Traffic Sign Recognition
    24 25.81%
  • Speed Limit on the Navigation System
    7 7.53%
  • A combination of the two, which VAG doesn't allow in Australia.
    62 66.67%
Page 21 of 30 FirstFirst ... 111920212223 ... LastLast
Results 201 to 210 of 300
Thread: A guide to enable EU specific features for AU Spec Tiguans
  1. #201
    May 2017
    I'm planning to get OBD eleven... on their aussie suppliers website there are instructions for quite a few tweaks for MQB platform.
    https://www.autoinstruct.com.au/manu...n-vcds-tweaks/
    Does anyone on here has any experience with it? Any good?
  2. #202
    Dec 2010
    Helensburgh
    It is a pity there is no explanation for each modification, half of them I don't understand what they do.
  3. #203
    Half (or almost) of them is implemented in stock configuration.
  4. #204
    Mar 2009
    Quote Originally Posted by IsDon View Post
    Yes it can. Works well.
    And it will enable dynamic routing.
    Pity I only just read this. Was in Melbourne over the weekend for the soccer and had the VCDS with me.
    It doesn't work for me.
    Steps I did as per this thread using OBDeleven
    TMC Traffic
    Go into Module 5F - Information Control Unit
    Select Adaptations, select "Fee-based traffic information (TMC)
    Set value from 65535 to 1024
    Make sure you enable traffic information in the radio, and set RDS region to automatic.
    I reset the unit. When I press traffic i have no new messages even in peak hour Melbourne traffic. with the little symbol at the top with a line through it.
    I'm extremely jealous that i'm unable to get it to work.
  5. #205
    Oct 2016
    When you go back into the module has it retained the 1024 setting?
    If it has then it has to be a setting you haven't enabled in either the radio settings or settings within the traffic page itself.
    Is this a discover pro you're trying this on?
  6. #206
    Mar 2009
    Yes it has retained its setting, I even reverted back to the old setting and re-applied it again.
    In the radio settings I have enabled TP Traffic program, Not sure there are any more settings in the Traffic page/button itself, I couldn't find any.
    No I'm using the Discover Media audio and satellite navigation system on the 132 TSI Comfortline.
  7. #207
    Oct 2016
    Quote Originally Posted by saveferris View Post
    Ok. It may be it it will only work on the discover pro.
    I've not played with the discover media audio system. Yours may not have the extra receiver built into the radio for the system to work.
    Has anyone else got it to work on your type of system?
  8. #208
    Mar 2009
    On page 12 a poster named hoola managed to get it to work with same system.
  9. #209
    Oct 2016
    Ok, well if that's true then you must be doing something wrong. It does take a few minutes to get any data to show, don't expect anything immediately.
    It's also dependent on FM reception so if you're not in an area with good FM Reception that may be an issue.
    It's also only available in capital cites. If you're not in one it doesn't work.
  10. #210
    Mar 2009
    I'm in Melbourne, Brighton area. I have given the unit plenty of time to update about 7 days worth lol. Not sure what I could have done wrong. The steps are pretty straight forward....ahh well.
