View Poll Results: Do you prefer Traffic Sign Recognition or Navigation Speed Limit
Voters
93. You may not vote on this poll
  • Traffic Sign Recognition
    24 25.81%
  • Speed Limit on the Navigation System
    7 7.53%
  • A combination of the two, which VAG doesn't allow in Australia.
    62 66.67%
Page 20 of 30 FirstFirst ... 101819202122 ... LastLast
Results 191 to 200 of 300
Thread: A guide to enable EU specific features for AU Spec Tiguans
  1. #191
    Mar 2009
    Does anyone know the setting in OBD eleven for automatic closing of windows and sunroof using rain sensor.
  2. #192
    Quote Originally Posted by saveferris View Post
    I tried to code it using VCDS and even with proper coding it didn't work with rain sensor - but I enabled comfort sunroof open/close with success.
  3. #193
    Mar 2009
    Have you managed to get TP to work....mine just won't update.
  4. #194
    did you reset the MIB unit after you made changes to the adaptation channel?
  5. #195
    Mar 2009
    I did factory reset just the radio settings. Or am I supposed to factory reset the entire unit?
  6. #196
    hmmm......... not entirely certain what "factory reset just the radio settings" is, but the MIB reset procedure is done like this:
    1. Turn-on the MIB unit (doesn't matter what part of the MIB is on the screen).
    2. Hold down the ON/OFF button on the LHS of the unit
    3. Keep pressing down the ON/OFF button until the screen turns-off AND then turns-on again (then release the button)
  7. #197
    Mar 2009
    Thanks for that will try it, what I have been doing is going into the settings of the MIB unit, then choosing factory reset, it gives you a choice of what component you want to reset, phone, radio Nav etc.
  8. #198
    Jan 2017
    Warrandyte
    Can traffic be enabled?
  9. #199
    Quote Originally Posted by Tigger162 View Post
    Tigger: I don't own a new Tiggy, but I've done it on a couple of forum colleague vehicles. Worked OK when I had the cars here and I've not heard of any problems thus far (case of no news is a good thing)
    That said, lets understand what is meant by "Traffic": we are referring to the Traffic reports that are sent over the FM commercial radio band. The SATNAV receives this data, it decodes the information and then, it visually displays the messages on the MIB screen. Updates are done in real time!
  10. #200
    Oct 2016
    Yes it can. Works well.
    And it will enable dynamic routing.
    Pity I only just read this. Was in Melbourne over the weekend for the soccer and had the VCDS with me.
