Originally Posted by
DV52
Bender: This tweak (setting the car type to Audi) has been floating about for some time now. A few of us over on the mk7 thread (which is also built on an MQB platform - like the new Tiggy) tried it. My experience with this tweak was that it did not make an appreciable difference (if any) to performance and that using the Audi setting caused an incompatibility problem with the ABS module. I can't remember now the exact error message, but the ABS complained bitterly until I reverted the setting back.
In a remarkable coincidence of happenstance (how's that for a tautology ?)- I've just been corresponding with a another colleague via PM about this very matter. My colleague (point) implemented a tweak which was first posted by XaGiCo and which was reported as dramatically changing the responsiveness of the vehicle. It goes like this:
1) Select Command Module: 44 - Steering Assist
2) Select Security Access: 16 Access Code 19249
3) Select Adaptation: 10
4) Select Driving profile switchover and Vary parameter 'Direct; controlled over threshold value'
Now, Ive personally not tried the tweak, but point reports that it has resulted in a much better responsiveness from his (her?) gearbox,
Thanks Don, sadly I will only be able to try these in late October once mine arrives
Is your tweak specifically for VWs or do you think that will also work on Skodas....if so I might twist my bros arm to try it?
2007 GOLF GTI - Reflex Silver | 5DR | DSG | Sunroof | Full Tint | Black Leather
2017 TIGUAN 162 - Indium Grey | R-Line | DAP | Pano Roof | Full Tint - Ordered 30/3/17 Collected 23/11/17
