Page 92 of 116 FirstFirst ... 42829091929394102 ... LastLast
Results 911 to 920 of 1156
Thread: Gen 2 Tiguan Wheels Thread
  1. #911
    Quote Originally Posted by REXman View Post
    These could be happening.
    Specs on wheels? They look a bit like Brixton PF8’s
    Gen 2 Tiguan Wheels Thread-green-audi-r8-gen-2-brixton-forged-wheels-pf8-gloss-black-20-1800x1200-jpg
    May 2010
    20inch 9.. rubber per convos, 255 45 20
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
  3. #913
    You want 255/40R20
    May 2010
    Definitely 40?
  5. #915
    R-line runs a 255/40R20 which is "standard" gen2 Tiguan fitment.
    If you were to fit 255/45R20 this would make the speedo out by 3.5% which is not recommended: Compare 240/40R20 to 245/45R20 willtheyfit.com
    If I was looking at tyres I'd seriously be considering these: Goodyear - EAGLE F1 ASYMMETRIC 3 XL FP 255/40R20 101Y
    May 2010
    Yeah it looks like either 255 or 265 with 40mm side walls is fine (0.52 or 0.6% difference). Thanks for that calc, pretty handy.
  8. #918
    Yes that's my go-to for wheel/tyre fitment. Put in your stock size and then the new size you're considering and it does everything for you.
    Generally you can change the width by 1 size up/down from stock and be OK.
    May 2010
    Any issues needing 66.6 to 57.1mm hub rings? Like long term or sound issues?
  10. #920
    Absolutely no issues. The hub ring does not take any load. They just allow you to centre the wheel on the hub when you bolt it up.
    My HRE’s were supplied with hub rings and also my OZ Racing wheels previously. It’s quite a common practice with aftermarket wheels that they will manufacture to 66.6 for Audi and supply hub rings for VW (instead of manufacturing/stocking both specs).
    Don’t get confused with spacers which aren’t legal in most states.
