Does anyone have any idea how much the VW 'Auckland' or 'Kapstadt' wheels cost swapped out from the standard high line rims?
So will I.
I recon they look too small in comparison to the car.
2017 Tiguan 162TSI Highline/R-Line
2017 Audi S3
On the Octavia it was just a steel safety rim with a normal tyre but still classed as a "space saver". Buy 4 and remove the stickers and you could do whatever speed you wanted on them.
Personally, I'd buy something that matched all the other rims with the std tyre size and then you aren't restricted in any way
Can I ask if the forum members who have already taken delivery of their Gen 2 Tiguan if you could please take a tape measure and measure the clearance between the inside spare wheel well and the bottom of the floor in both the lower floor and upper floor positions.
I am trying to work out what size proper spare and rim I can squeeze in (if possible).
Many thanks
David
Sent from my SM-G930F using Tapatalk
Ordered: 2017 build date Tiguan 162 TSI Highline with DAP in Tungsten Silver and rear luggage tray. ETA: late April / Early May. I did not have to wait.I took delivery on 11 March 2017.
Wait til you get the price on the wheels, 17" $1386.00. Each.
I have picked up a set of 17" Tulsa wheels and tyres brand new for $750 off Gumtree, the owner put on 19" aftermarket wheels. I have 20" Suzuka and need the set for winter for snow chains, I have tested in the spare wheel space and it is a couple of centimetres too high for the cover.
I plan to put in a full size spare replacing the space saver. I will be using some well spaced timber blocks (with Velcro top and bottom) to stabilise the boot tray. I may also remove the foam molding to gain extra storage under the tray. It may not be ideal, but it will be most useful when I get a flat 100's of KMs from the nearest tyre repair place. Also the flat tyre will fit properly in the spare wheel well.
(Zero sum gain.)
