Page 113 of 116 FirstFirst ... 1363103111112113114115 ... LastLast
Results 1,121 to 1,130 of 1156
Thread: Gen 2 Tiguan Wheels Thread
  1. #1121
    Feb 2014
    Hi guys I have a 2017 Tiguan with the 255/45R20 Suzuka wheels. The plate on the drivers side door indicates 235/55R18 as one of the OEM sizes. Am I correct in assuming that if i switch out for this size then the speedo will still be ok? Does anyone know where I find the rim offset information for myself?
    Also how do I go about making sure the Typre Pressure Monitoring will still work if I switch rims?
    I'd like to switch out to Yokohama Geolanders
    Many thanks in advance and Merry Belated Xmas!
    Sent from my SM-G973F using Tapatalk
  2. #1122
    Feb 2014
    Are the wheel sizes on the placard strictly the only sizes compatible etc?
  3. #1123
    Sep 2007
    Rowville, Victoria
    Quote Originally Posted by LaNOS View Post
    By switching out to an OEM wheel and tyre size, your speedo will be fine. Almost an imperceptible difference that any mere mortal will notice.
    I cannot assist with the offset though.
    As far as the TPMS goes, VW generally use the ABS sensors to detect different rotational speeds as an indicator of tyre pressure differences. At least my old MY07 Jetta and my current MY21 Tiguan uses the ABS sensors.
    Best wishes
    BeigeJet
    White MY23 Tiguan 147 TDI Elegance (mine)
    White MY21 Tiguan 147 TDI Elegance (wife)
    Gone - Wheat Beige MY07 Jetta TDI manual
  4. #1124
    Feb 2014
    Quote Originally Posted by BeigeJet View Post
    Best wishes
    Thanks for that! Makes this endeavour much more simple!
  5. #1125
    Feb 2014
    I see the OEM 18s for the Tiguan are 235/55R18 with offset 43 and width 7. Some listed aftermarket options are offset 45 and width 8. Does anyone know if these values work?
  6. #1126
    You can afford to go up to 35 offset with 9" width on a non-Rline (or +30 and 8.5" width). That's what I'm running and the fronts are just inside the line of the guard.
    The 18/19x8 +45 is typical Golf aftermarket size to get flush fitment. You can afford to be ~10-15mm more aggressive with width/offset than Golf setups. You can always measure your current setup to see how much clearance you have and how much more width/offset you can run. punch the numbers into an online calculator will tell you the (relative) fitment between your stock set-up and the one that you're proposing: Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
    Feb 2014
    I have the Rline, what difference does that make compared to non-rline? Is it the brakes/rotors?
  8. #1128
    Dec 2021
    Montreal
    Trying to figure out if a 18x9 et25 with 265/45R18 will rub
    Got my Team Dynamics Pro Race 1.2 powdercoated in satin black
    Gen 2 Tiguan Wheels Thread-6624008351-jpg
  9. #1129
    Dec 2021
    Montreal
    Back from the powedercoating !
    Gen 2 Tiguan Wheels Thread-20211229_102428-jpg
  10. #1130
    R-line has (slightly) flared arches which allows another ~10mm offset/width.
