The tyres ability to dispel water goes down with the tread depth. So even if you have "legal" tread in the middle if your corners are scrubbed out it still doesn't help to allow the water to move out of the tyre. Long story short if your corners are scrubbed out then you need to replace them and get a better alignment done. Ideally you should have even wear right across the face of the tyre.
- You may not post replies
- You may not edit your posts
Forum Rules
