Originally Posted by
dptiggie
Thanks both. Great help tigger. Would you in my shoes look to get a stock tyre re-fitted? That’s what I’m planning to do. I don’t like the idea of a different tyre with different properties on one wheel, though the differences are likely slight. I expect VW would say the same.
Yep the sealant didn’t help me- went a little too spiritedly around a roundabout, and clipped the curb on way out. Hole in the shoulder of the tyre for my troubles. So couldn’t be repaired. Quite painful being that there were only 300km of wear on the tyre.
After the beeping alert, I did check the tyre pressures and it was 240 psi. Compared to 280 psi on the other 3 tyres. Have moved them all to 260 and reset all the pressures, now waiting to see how that goes.
