Originally Posted by
drivesafe
Thank you very much Hillbilly, I have quite a bit of reading to do.
Yet to find anything about the seat controls, but I guess I will eventually.
Again Thank you for the links.
NO worries Should be in the electrical section I sold mine so no longer interested much. HOWEVER I had a problem with the auto seat adjust.
Solution was that I had it too far back in the user position and if its back beyond a certain point it wont adjust or move at all. Took it in to VW and the Workshop manager said it would need a new base for $1032. I remembered that when it had a flat battery it wouldnt work either. So did further investigation and a mechanic told me how to fix it and he put two bits of tape on seat and slide so I could see that it wouldnt be too far back.Only needed to move forward about 30 mm and no more trouble
