Results 11 to 20 of 29
Thread: Factory vs dealer fitted towbar
    Sunshine coast
    I found these instructions btw; Hitch Install P2 001 | Brian Wilson | Flickr
    A bit concerning is the warning to not install this kit on a 7 seater Allspace. I'm wondering if this is simply a warning to not tow anything when anyone are in the rear seats, or if there's another kit for the 7 seater Allspace?
    132TSI Tiguan Allspace
    Jun 2011
    Is your bar the same part number?
    I have the instruction to fit 5NA092136 bar. it looks a little different. Shorter arms that connect to the subframe.
    5NA092136 Installation Its listed as a part number for Tiguan Allspace 5N 2018- and Tiguan AD1 2016-
    Interestingly. On the us parts website Trailer hitch kit lists part number 5NN092135 as the 5/7 seat models. nad 5NA09135 as for 5 seaters only. (I think USA had LWB 5 and 7 seaters).
    Sunshine coast
    Yes your instructions fit mine exactly! It also shows the bolts, nuts and washers. I guess I need to get some extra from a VW dealer.
    Factory vs dealer fitted towbar-pxl_20200924_041516257-jpg
    Jul 2007
    Brissy
    I doubt you need to go to a VW dealer to pickup some washers. Mitre 10 or Bunning would be easier and cheaper
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Sunshine coast
    Just wanted to make sure they're the right specs. Btw, I guess the rearmost seatrow has to come out in order to get to the cabling. Found this image Euro Car Upgrades added a new photo — at... - Euro Car Upgrades | Facebook
    Jun 2011
    Yes. but it is a relatively easy job. Just take photos before you pull plugs and cables out and see how the seat sensor cables are routed before disconnecting.
    You will need to do the CAN-BUS connection under the steering wheel as well.
    Sunshine coast
    Got the wiring harness in. Getting the seats out made all the difference. There's a lot of clips behind that panel. Factory vs dealer fitted towbar-pxl_20201003_040249712-jpg Factory vs dealer fitted towbar-pxl_20201003_040301057-jpg Factory vs dealer fitted towbar-pxl_20201003_065455351-jpg
    Dec 2012
    Just started looking at getting a VW tow bar fitted to my Tiguan 162 Allspace and found 5NA092136 to be the part. Looking to buy this second hand.
    Would anyone know if I would need to buy an additional wiring harness from VW?
    I downloaded installation instructions for the bar, but there is nothing about the wiring harness (attached).Tapatalk Cloud - Downlaoad File Tiguan%205N%20AD1%20Towbar%20Fitting%20Instruction s_1_230617_210937.pdf
    Sent from my SM-S908E using Tapatalk
    MY11 B7 Passat 125TDi Highline
    Pearl Mocca Anthracite | Electric and Heated Leather | Folding Mirrors | Sunroof | Adaptive Lighting Package | Footwell Lighting | Park Assist 2 | Lane Assist | RNS510 | R36 Pedals | Scirocco MFSW | Front Lip | 20" Suzuka Wheels | H&R Springs | De-Badged | VCDS Mods | Alpine Mono and 8" Subwoofer
    Nov 2010
    Canberra
    Looks similar to one I fitted to my 2017 R-Line which included the wiring loom as shown in the diagram - my part number (still have the box) was 5NA055202B - I am aware there were many variants and from memory it was discontinued early 2020 so no idea what happened after that. I do remember connecting the wiring block behind the dash on the drivers side (states the glove box for LH drive versions) and then drove to my dealer and they coded it...have never had any issues since - HTH
    Dec 2012
    Quote Originally Posted by dmn View Post
    I can't find 5NA055202B online.. Was this your wiring harness/module?
    The towbar kit only comes with the plug harness, not the module to connect to the cars BCM or go to the dash area
