Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Examples of Static, Dynamic cornering lights and DLA
    Oct 2015
    cornering lights(static and dynamic) (and low beam reference point)
    DLA (oncoming traffic first half, following a car second half)
    Feb 2019
    Perth, WA
    Thanks for the videos!
    Did these come standard on your 2018 Allspace or activated via OB11/VCDS?
    Dec 2010
    Helensburgh
    That shows it well, pity it does not lower the lights on a T intersection, technology sucks sometimes! I think we need a sticky explaining what each mode is to fix all the confusion because DLA has been used so many times over the years for different things as technology has advanced.
    Oct 2015
    Quote Originally Posted by phonebooth View Post
    Standard. This might be what Ozsko means by the 2018 introduction. I’m fairly sure it’s just that they enabled the feature for the allspace to help justify its 3k price difference (coz the rear seats are basically useless. Buy the allspace for the bigger boot)
    Dec 2010
    Helensburgh
    The first I heard of DLA on a Tiguan in Australia was when someone mentioned it on an Allspace they had bought. I am still confused if the European SWB car has the mid type lights and they have been activated. I should call into a dealer and have a look at what headlights are in the SWB car. Some owners think they have activated DLA but doubts have been expressed that this is the case. It has also become mixed in with the Passat discussions on the subject which has added to the confusion at least for me.
    Does the Allspace arrive with DLA from the factory or does it have to be coded?
    Do the SWB European cars now have the Mid type headlight assemblies? If so is DLA active from the factory or does it have to be coded? If your car SWB has mid LED assemblies when was it sold?
    Signed
    Confused
    Oct 2015
    Allspace is activated from the factory.
    All Tiguan highlines (since 2016 model) have the ‘mid’ lights. Allspace and swb. Not sure of comfortline.
    Dec 2010
    Helensburgh
    Simon, mine is very early 2016 model and it has not got the mid lights, when did they start fitting them?
    Oct 2015
    Assuming you have a highline, then from day1. Do you have a comfortline?
    Maybe some cars arrived here with the low level led fitted- based on supply during the day of assembly, since we don’t use the dla feature in Aus.
    A 25/1/17 test of a highline had the mid level lights. So that car was built in mid-late 2016.
    All the cars I find on Carsales and google have the mid level lights (highline)
    Dec 2010
    Helensburgh
    No, mine is a Highline. I too initially thought that the DLA function could be enabled because all the UK cars had it but then I discovered that there were two headlight assemblies and we were not getting the DLA capable unit. When Kamold got hold of the coding we gave it a go and when it did not work I did some investigation to find mine can't be done.
    Oct 2015
    Do you only have the 2 little single DRL’s in your headlights, rather than the eyebrows and the ‘U’ shaped ones?
    What build month is your car?
    Edit- after googling and looking at every 2016-2017 tiguan highline for sale on carsales, every car has the mid level lights.
    Vw official brochure also says that the highlines get the led lights with active cornering and just halogens for comfort/.
    You’ve gotten a car with the wrong headlights fitted, or it’s not a highline (but I think you know what you’re driving!) or when the coding was being attempted, that mistakes could’ve been made?
    Can you upload a pic of your car headlights with the headlights off (so only drl are lit)
