Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
Thread: Electric seat dead after battery test
    May 2023
    Melbourne, VIC
    Quote Originally Posted by MIG View Post
    You can connect directly to the module; my first bench setup was a cheap OBD female connector and hooked up the following pinout.
    4, 5 = Gnd
    16 = Bat+
    6 = CAN H
    14 = CAN L
    You can tell the CAN wires are coloured (orange with a colour band = CAN H) (orange with a brown band = CAN L)
    I have successfully connected directly to the seat module using this female OBD connector:
    https://www.amazon.com.au/dp/B07F16HC12?ref=ppx_yo2ov_dt_b_product_details&th=1
    Electric seat dead after battery test-51k-vnhrzll-_ac_sl1500_-jpgElectric seat dead after battery test-61cyh4zxual-_ac_sl1024_-jpg
    This is probably well known be experienced members here, but I had to select the seat module directly under Select Control Module.
    This is my initial scan:
    Code:
    Friday,26,May,2023,21:27:33:45971
    Code:
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
    Data version: 20220830 DS341.0
    www.Ross-Tech.com
    VIN: WVGZZZ5NZKW833436   License Plate:
                    Address 36: Seat Mem. Drvr
    Control Module Part Number: 5Q0 959 760 C
      Component and/or Version: Sitzmemory    H09 0024
               Software Coding: 001400020000050001C280808180000000008181000000F400
                Work Shop Code: WSC 12345
                          VCID: 3D273DAAADFA97D3CC5-8068
    Advanced Identification/FAZIT
         Serial number: Y0006RJJ39570
         Identification: KO1-ABY
         Date: 19.10.18
         Manufacturer number: 3201
         Test stand number: 9570
    Flash Status
         Programming Attempts(application): 0/0
         Programming Attempts(data): 1
         Successful Attempts(data): 1
         Flash Date: 00.01.01
         Flash Tool Code(data): 40022 666 40022
    Misc.
         Hardware number: 5Q0 959 760 C
         Workshop System Name: J810
         Equipment/PR Code: 000000000000000000000000
         Dataset Number: -----------
         Dataset Version: ----
         ASAM Dataset: EV_SeatMemorDriveSide
         ASAM Dataset Revision: 002022
    VCDS Info:
           Labels: NONE
           ROD: EV_SeatMemorDriveSide.rod
    Under Basic Settings, there are 3 options:
    1. IDE02325-MAS00675-Reset to factory setting
    2. IDE02854-MAS00675-Reset standardization
    3. MAS05563-MAS00675-Norming
    I am reluctant to perform reset to factory settings as I've read other people having headaches when doing this.
    I have performed IDE02854-MAS00675-Reset standardization on all seat motors successfully.
    When I first tried MAS05563-MAS00675-Norming, I got the following error: ERROR: Vehicle speed too high. This was easily fixed by going to Adaptations and changing ENG123066-vehicle_velocity_monitoring from active to not active. Now when I try Norming, I get the following error: ERROR: Conditions not correct or request sequence error.
    When I go into Output Tests and try each option to manually operate the motors, I get the following errors:
    Electric seat dead after battery test-refusedbycontrolmodule_all-jpg
    May 2023
    Melbourne, VIC
    These are the faults that persist:
    Code:
     Saturday,27,May,2023,00:49:32:45971
    Code:
    VCDS Version: Release 23.3.1 (x64) Running on Windows 10 x64
    www.Ross-Tech.com
                   Address 36: Seat Mem. Drvr       Labels: NONE
    Control Module Part Number: 5Q0 959 760 C    HW: 5Q0 959 760 C
               Work Shop Code: WSC 12345 123 61029
                 ASAM Dataset: EV_SeatMemorDriveSide 002022 (VW37)
                         VCID: 3D273DAAADFA97D224D-8068
    7 Faults Found:
    9655636 - Motor for Seat Fore/Aft Adjustment
             B1355 54 [009] - Missing Calibration / Basic Setting
             Confirmed - Tested Since Memory Clear
                Freeze Frame:
                       Fault Status: 00000001
                       Fault Priority: 4
                       Fault Frequency: 1
                       Reset counter: 81
                       Date: 2000.00.00
                       Time: 00:00:00
    9655892 - Motor for Seat Backrest Adjustment
             B1356 54 [009] - Missing Calibration / Basic Setting
                Freeze Frame:
                       Fault Priority: 4
                       Fault Frequency: 1
                       Reset counter: 81
                       Date: 2000.00.00
                       Time: 00:00:00
    9655380 - Motor for seat height adjustment
             B1354 54 [009] - Missing Calibration / Basic Setting
                Freeze Frame:
                       Fault Priority: 4
                       Fault Frequency: 1
                       Reset counter: 81
                       Date: 2000.00.00
                       Time: 00:00:00
    9655124 - Motor for Seat Tilt Adjustment
             B1353 54 [009] - Missing Calibration / Basic Setting
                Freeze Frame:
                       Fault Priority: 4
                       Fault Frequency: 1
                       Reset counter: 81
                       Date: 2000.00.00
                       Time: 00:00:00
    9654868 - Motor for Lumbar Support Fore/Aft Adjustment
             B1352 54 [009] - Missing Calibration / Basic Setting
                Freeze Frame:
                       Fault Priority: 4
                       Fault Frequency: 1
                       Reset counter: 81
                       Date: 2000.00.00
                       Time: 00:00:00
    9654612 - Motor for Lumbar Support Height Adjustment
             B1351 54 [009] - Missing Calibration / Basic Setting
                Freeze Frame:
                       Fault Priority: 4
                       Fault Frequency: 1
                       Reset counter: 81
                       Date: 2000.00.00
                       Time: 00:00:00
    10489856 - No Basic Setting
             B2010 00 [009] - -
             [keine oder falsche Grundeinstellung/Adaption]
                Freeze Frame:
                       Fault Priority: 7
                       Fault Frequency: 1
                       Reset counter: 81
                       Date: 2000.00.00
                       Time: 00:00:00
    Mornington Peninsula, VIC
    I should have mentioned you needed to select the module when you don't have a gateway in the mix.
    Check the advance measuring values; my guess is the seat is missing a signal it wants from the rest of the car before enabling the motors, just like you had with the speed too high warning.
    At least you know the controller is good.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    May 2023
    Melbourne, VIC
    I purchased another set of seats yesterday from another wreckers, both full electric with memory and the R-Line emblem.
    From here on, I will refer to them as:
    Seat 1: The seat I have working with so far. From Tiguan 1. Appears to be the same as R-Line just no emblem or white stitching. Full electric with memory buttons.
    Seat 2: The drivers seat from Tiguan 2. R-Line emblem, white stitching full electric with memory buttons.
    Seat 3: The passenger seat from Tiguan 2. R-Line emblem, white stitching full electric with memory buttons.
    I have compared the advanced measuring values between Seat 1, Seat 2 & Seat 3. The only difference in advanced measuring values I have found is this:
    Seat 1:
    IDE01457 Energy management deactivation stage Deactivation stage 3
    Seat 2:
    IDE01457 Energy management deactivation stage Deactivation stage 0
    Seat 3:
    Seat 1 is still not operational with the following faults:
    9655636 - Motor for Seat Fore/Aft Adjustment B1355 54 [009] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 81
    Date: 2000.00.00
    Time: 00:00:00
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 81
    Date: 2000.00.00
    Time: 00:00:00
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 81
    Date: 2000.00.00
    Time: 00:00:00
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 81
    Date: 2000.00.00
    Time: 00:00:00
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 81
    Date: 2000.00.00
    Time: 00:00:00
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 81
    Date: 2000.00.00
    Time: 00:00:00
    B2010 00 [009] - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 81
    Date: 2000.00.00 Time: 00:00:00
    Seat 2 is operational with the following faults:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 68276 km
    Date: 2023.03.04
    Time: 15:26:26
    B2010 00 [009] - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 68276 km
    Date: 2023.03.04
    Time: 15:26:26
    Seat 3 I have not operated any of the buttons yet. No faults present.
    Edit: I have operated Seat 3 (except for the memory buttons) and still no fault codes. I have noticed an extra option under Basic Settings that is not on Seat 1 & Seat 2:
    IDE02404-MAS00675-Checksum calculation
    May 2023
    Melbourne, VIC
    No wonder I am getting faults still...the module has, for some reason decided that the maximum and minimum travel values are the same. Not to mentioned the supposed current position of all the motors is exactly the same down to 1 step accuracy and outside the max/min range.
    Any idea on how to correct this? I've tried numerous attempts of IDE02854-MAS00675-Reset standardization & MAS05563-MAS00675-Norming. Reset standardization passes instantly and Norming comes back with the following error: ERROR: Conditions not correct or request sequence error.
    Electric seat dead after battery test-motorvalues-jpg
    Jul 2017
    Quote Originally Posted by Bezzey View Post
    I didn't realize that you upgrading original Tiguan seat to Different car.
    Unfortunately your problem is not with wiring even if you connect all correct wires, you will still have problem . That seat is programmed to Specific VIN in Tiguan, as soon you connect to different Car VIN ( it read from car Gateway Vin than compare VIn stored in Seat control module) , it stop working. You need VW dealer or someone with original VW tool to program and flash module to suit your new VIN and car model.
    Jul 2017
    What exactly model is your Amarok ? Year made?
    If you are in Sydney , i would be maybe able to help , however you are in VIC.
    May 2023
    Melbourne, VIC
    @cameleon72 I am planning to simply wire up power and air bag only to my Amarok as like you said I will run into issues with different components. There's not really any good reason to wire it up to my Amarok other than power and airbag, as the seat can operate independently I believe. I have been bench testing successfully except for memory buttons.
    See page 1 for my Amarok info in the auto scan.
    Pacific Paradise QLD
    Memory probably wont work as needs to be connected to something to store the settings wouldnt it.
    May 2023
    Melbourne, VIC
    From what ive read, my understanding is that the seat module stores these settings.
