Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Electric seat dead after battery test
    May 2023
    Melbourne, VIC
    Unhappy Electric seat dead after battery test
    I got a front drivers seat from a 2019 Tiguan Highline and was testing it with direct power today with a battery. After using the position controls, I pressed one of the memory position buttons. The seat began moving to the memory position for about 1 second and then stopped. I did this a couple more times with the same response from all 3 position buttons.
    I then went back to using the position controls and within a few seconds the seat went dead.
    I've done the following:
    • Tried a different battery
    • Removed the controller circuit board to inspect for anything burned
    • Disconnected each button control module 1 at a time
    • Tested each motor with direct power - all ok
    Have I fried the control board? Pics attached for reference.
    Electric seat dead after battery test-aa0ad4d4-8a85-4e31-818c-e103db58825a-jpgElectric seat dead after battery test-20230522_163200-jpgElectric seat dead after battery test-20230522_230217-jpgElectric seat dead after battery test-test-pins-jpgElectric seat dead after battery test-20230523_101627-jpg
    Pacific Paradise QLD
    One thing to note with these seats is if you have it back beyond a certain point it wont return to its set place It also wont reverse for easy exit. Mine did it and VW put markers on side of seat to show where not to move it back past. Aslo wont work if voltage drops too far.
    Dont know about a Tig but the base with all the gear in for a Passat is just over $1000
    May 2023
    Melbourne, VIC
    This is what I'm thinking has happened. I'm looking at the idea of wiring up the seat to my Amarok in order to access it with VCDS to clear faults/recalibrate or something like that.
    Mornington Peninsula, VIC
    My guess would be the seat controller is looking for a can bus signal to say the ignition is on something like the Klemmen_Status_01 on the MQB platform.
    Do you have a scan tool? You can directly hook it up to the CAN high and low pins in the harness and see if it communicates.
    Or you could try creating a test bench setup like in this thread Testbench setup? | Page 10 | Ross-Tech Forums
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    May 2023
    Melbourne, VIC
    I have VCD and a OBD bluetooth dongle. If I identify the CAN pins on the seat control module and the OBD connection, can I communicate with it that way?
    I will look into the test bench thread you linked.
    Jul 2017
    Quote Originally Posted by Bezzey View Post
    Hi
    connect to OBD2 with VCDs and look and search for module 36 .
    ECU: 0036 - Seat Adjustment Driver Side
    See if you can log into DTC error any messages there. If you can access coding , adaptation of module 36 , than Can communication from driver seat to Car is fine and control module is responding to car gateway, But you my have some other problem which need to be addressed with special VW software only .
    Regards
    May 2023
    Melbourne, VIC
    Where should I connect the module to my Amarok? Or is there way to connect directly to the seat module without a vehicle? Here is an old auto scan from my Amarok:
    Saturday,13,February,2021,13:00:49:45971
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
    Data version: 20201125 DS322.1
    Ross-Tech: Home
    VIN: WV1ZZZ2HZEA031608 License Plate: 1BC5BZ
    Mileage: 211570km-131463mi Repair Order:
    Chassis Type: 2H-VN81 (6N0)
    Scan: 01 02 03 04 08 09 10 15 17 19 25 32 37 56 69 6C 0B
    VIN: WV1ZZZ2HZEA031608 Mileage: 211570km-131463miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    32-Differential Locks -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    56-Radio -- Status: OK 0000
    69-Trailer -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: OK 0000
    Address 01: Engine (J623-CSHA) Labels:. 03L-906-022-CFC.clb
    Part No SW: 03L 906 012 AF HW: 03L 907 309 AC
    Component: R4 2,0L EDC H24 5936
    Revision: 74H24--- Serial number: 00000000000000
    Coding: 012A4012233600080001
    Shop #: WSC 29131 001 1048576
    ASAM Dataset: EV_ECM20BTD01103L906012AF 001009
    ROD: EV_ECM20BTD01103L906012AF_001.rod
    VCID: 6889BCFE92F8E27BDB2-803C
    7 Faults Found:
    4807 - EGR System
    P0401 00 [096] - Insufficient Flow
    Intermittent - Not Confirmed - Tested Since Memory Clear
    12306 - Particulate Trap Bank 1
    P2002 00 [096] - Efficiency Below Threshold
    4814 - System Voltage
    P0562 00 [032] - Too Low
    10065 - Mass Air Flow Sensor (G70)
    P0104 00 [032] - Intermittent
    4881 - EGR Valve (N1
    P1440 00 [032] - Open Circuit
    9120 - EGR Sensor 1
    P046C 00 [096] - Implausible Signal
    4629 - ECM Power Relay Load Circuit
    P068A 00 [032] - Opens Too Early
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J217) Labels:| 0CM-325-025.clb
    Part No SW: 2H0 927 158 D HW: 0CM 325 025
    Component: 2H0 20RTDIRdW H16 3001
    Revision: --H16---
    Coding: 000001
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_TCMAL450211 002011
    ROD: EV_TCMAL450211_002_VN81.rod
    VCID: 2E050AE6709C7C4BD1E-807A
    No fault code found.
    Address 03: ABS Brakes (-----) Labels: None
    Part No SW: 2H0 907 379 M HW: 2H0 907 379 D
    Component: ESP MK25A XT H44 0111
    Revision: 00H44001
    Coding: C07324B69997039624A899A3AF58F0
    Shop #: WSC 07456 790 49164
    VCID: 3A2D36B6BC54A0EB7D6-806E
    Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
    Part No SW: 2H0 907 040 E HW: 2H0 907 040 E
    Component: ClimatronicT5 H19 0406
    Revision: 00001003
    Coding: 0000000002
    Shop #: WSC 07456 790 50316
    ASAM Dataset: EV_ClimatronicT5 A01003
    ROD: EV_ClimaAutoT5Basis.rod
    VCID: 2313EBD22B5EC1234E0-8076
    Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
    Part No SW: 7H0 937 090 B HW: 7H0 937 090
    Component: BCM PQ25 Max4 H74 0712
    Revision: B9074001 Serial number: 0571 263130671
    Coding: 240002380C61040093380E302CCB86C50F80610F6080204130 0000020003
    VCID: 2D070DEA7D1A0753E84-8078
    Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 231013 05 54 0403
    Coding: 02302D
    Subsystem 2 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
    Component: J386__TSG_FT 002 3323
    Serial number: --------------------
    Coding: 050000
    Subsystem 3 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
    Component: J387__TSG_BT 002 3323
    Coding: 050000
    Subsystem 4 - Part No: 1K8 951 171 A
    Component: DWA-Sensor 00 001 0103
    Coding: 000000
    Subsystem 5 - Part No: 1K8 951 605 B
    Component: LIN BACKUP HO H11 9005
    Coding: 000000
    Subsystem 6 - Part No: 1K8 951 171 A
    Coding: 000000
    Subsystem 7 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
    Component: E221__MFL-TAS H31 0037
    Serial number: 0304767
    Coding: 820000
    Subsystem 8 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
    Component: J388__TSG_HL 002 3323
    Coding: 000000
    Subsystem 9 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
    Component: J389__TSG_HR 002 3323
    Coding: 000000
    Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
    Part No SW: 7E0 919 475 L HW: 7N0 919 475
    Component: PARKHILFE 8K H06 0106
    Revision: -------- Serial number: 28261329903763
    Coding: 318103
    ASAM Dataset: EV_VW75XParkAssis8K 001003
    ROD: EV_VW75XParkAssis8K_001_VN75.rod
    VCID: 3B2333B2B3EE99E3660-806E
    Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
    Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
    Component: VW10Airbag00H H07 0013
    Revision: -------- Serial number: 003HN00EWKT9
    Coding: 000000000000000000000000000000003048
    Shop #: WSC 07446 790 50316
    ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
    ROD: EV_AirbaVW10BPAVN750.rod
    VCID: 33331B929BBE51A3BE0-8066
    Crash sensor for side airbag: driver side:
    Serial number: 3495RRB401I50O3MRHME
    Front Passenger's Side Airbag Crash Sensor:
    Serial number: 3505RRB401850O3MB0QA
    Crash sensor for front airbag: driver side:
    Serial number: 3555YRB400M50FMEQGUT
    Crash sensor for front airbag: front passenger side:
    Serial number: 3565YRB400M50FMEP9ME
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 2H0 920 871 HW: 2H0 920 871
    Component: KOMBI H04 0709
    Coding: 151A00
    Shop #: WSC 07456 000 09999
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
    VCID: 6597B5CA65EAFF13E04-8030
    Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 7H0 937 090
    Component: GW-K-CAN TP20 H74 0712
    Revision: B9074001
    Coding: 742300
    VCID: 70B9D49EAAA82ABB832-8024
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H04 0709
    Serial number:
    Coding: 000000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
    ROD: EV_Immo_UDS_VDD_RM09_VW23.rod
    VCID: 6A8DC6F68CF4D06BCD6-803E
    Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
    Part No SW: 2H0 927 771 A HW: 2H0 927 771
    Component: Quersperre H04 0017
    Revision: 11001001 Serial number: 4DG 16.10.13 00
    Coding: 000001
    ASAM Dataset: EV_QuersUDSAAMVN817 A01606
    ROD: EV_QuersUDSAAMVN817.rod
    VCID: 2C0100EE46800E5BFFA-8078
    May 2023
    Melbourne, VIC
    Continued below...
    Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
    Part No SW: 3C8 035 279 K HW: 3C8 035 279 K
    Component: RNS315-EU H78 0408
    Serial number: VWZAZ2S0986357
    Coding: 000004110200160000031002
    Shop #: WSC 10314 002 1048576
    ASAM Dataset: EV_RNS315EUV2UDS 001705
    ROD: EV_RNS315EUV2UDS.rod
    Data carrier:
    Subsystem 1 - Part No: 3AA 919 866 E
    Component: AUS_V1 0043
    Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
    Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
    Component: Anhaenger H09 0100
    Revision: 3A001001 Serial number: 00008030467966
    Coding: 0100000100000000
    VCID: 3039149E6A286ABBC32-8064
    2 Faults Found:
    02563 - Trailer; Right Tail Lamps (M61)
    010 - Open or Short to Plus - MIL ON
    Freeze Frame:
    Fault Status: 11101010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 154
    Mileage: 210779 km
    Time Indication: 0
    Date: 2015.06.22
    Time: 19:06:08
    02564 - Trailer; Left Tail Lamps (M60)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 154
    Mileage: 210779 km
    Time Indication: 0
    Date: 2015.06.22
    Time: 19:06:08
    Address 6C: Back-up Cam.
    Cannot be reached
    End----------(Elapsed Time: 02:35, VBatt start/end: 12.1V/12.1V)-----------
    You can connect directly to the module; my first bench setup was a cheap OBD female connector and hooked up the following pinout.
    4, 5 = Gnd
    16 = Bat+
    6 = CAN H
    14 = CAN L
    You can tell the CAN wires are coloured (orange with a colour band = CAN H) (orange with a brown band = CAN L)
    May 2023
    Melbourne, VIC
    I've ordered this cable:
    iKKEGOL 1ft Feet 30cm/12 16 Pin J1962 OBD OBDII OBD2 Female Connector Car Diagnostic Extension Cable Cord Pigtail DIY Mobley Adapter https://amzn.asia/d/cZuSa3s
