Results 11 to 20 of 33
Thread: Eco mode
    Feb 2018
    Anecdotally, I have used eco on the same trip as using sports..
    With eco I got around 7.8l and in sports is was around 9.8ish..
    This was a 30 minute drive into the city on the motorway in free flowing traffic..
    Not really worth it in my opinion
    Sent from my SM-N950F using Tapatalk
    Feb 2015
    Melbourne, VIC
    Ok, so regardless of whether Eco is used or not does the driving mode stay the same if for example you use Sport?
    Quote Originally Posted by Grugly View Post
    Do ECO vs Normal for a better comparison. Sports holds the gears, changes the shift points - not a fair comparison.
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
    Feb 2015
    Melbourne, VIC
    Quote Originally Posted by Dose Pipe Sutututu View Post
    Exactly that. My bet is small to no difference between Eco and Normal. I notice the gears are chased up through the box quicker in Eco and then out of gear when coasting, assuming to achieve the best possible fuel consumption.
    Feb 2015
    Melbourne, VIC
    Just an update on this... took it back to dealer and was told that it's completely normal behaviour for the instrument panel to show 'D' indicating 'Normal' mode and still showing 'Eco' within the driving profile on the infotainment system. The service advisor did not know why it did this but stated it even tells you this in the manual. It's not really an issue rather just a tad annoying, as one part of the system is saying one thing and another something else. IF I can be bothered I might take it up with VW, but considering the amount of times I actually use 'Eco', hmmm, probably not.
    Sep 2009
    WA
    Blog Entries
    1
    To get eco mode back fast, just turn the 4x4 selector know to snow and back again. If you had eco mode as the last profile, it will switch back to it.
    Jul 2018
    VIC
    Quote Originally Posted by anonymousmoose View Post
    thanks for the tips, i noticed drive mode selector takes quite sometimes to load up when starting the car.
    Dec 2017
    This problem really annoys me. I have a Mk 7 Golf and it remembers whether you left the Car in Eco or Sport mode whenever you start it up.
    This other problem I find that if I have 'Eco' selected as the drive mode in the 'Individual' setting, the engine coasting feature doesn't work. It only works if you select the full 'Eco' mode.
    Wish VW would fix this with a software update, but they don't seem interested
    Feb 2015
    Melbourne, VIC
    This is great and works well as a band aid but as the previous person said it really only compenates for VW's poor software. Both parts of the driving mode should sync whether on the infotainment or instrument panel.
    Feb 2015
    Melbourne, VIC
    **UPDATE**
    Ok so I did decide to pursue this with VW Australia and this is the response I got :
    As per our conversation yesterday, I have received a response from our Technical department here at Volkswagen Head Office and they have supplied me with the following response to your inquiry:
    After calendar week 22/17, this function has been changed, where after an ignition cycle (bus-silence), the gear selection will revert back to “D” mode.
    This cannot be changed and is a characteristic of design and meant to be this way.
    Please also refer to the owner’s manual section - Selecting driving profiles
    The driving profiles Sport and Eco will also remain set after the ignition has been switched off.
    However, settings for the engine and DSGEco mode dual clutch gearbox may switch to the Normal driving profile when the ignition is switched on again.
    In order to reactivate the Sport and Eco functions, you must re-select the Sport or Eco driving profile or move the selector lever to “S” for the Sport profile.
    So the question is whether this is an acceptable answer from VW, IMO probably not. Live with it or go further?
