Originally Posted by
Simonr23
Easiest way, using the power wires of that 12v socket, would be to splice into it with those plastic ‘snap over’ connectors. I can’t recall the proper name- sorry. I used to sell and use them, too!
They’re cheap and easy, but not always reliable in the long term. Especially if you get the wrong size for the cables being used (blue, red, yellow dictate cable thickness- rather than for any other reason)
They are called Scotchlocks and are the WORST possible way to join cables. Have seen them actually cut the wires inside the sheathing. Devils spawn should be their name
To imapivot if you are installing a 2 ch dash cam the cable from the front camera also powers the rear one. I have two independent cameras and I ran a wire along the floor trims to the rear to a spare ciggy socket from a fuse and used that. You also need an earth and I used a point in the rear quarter behind the tail lights where there was a piece of metal available. Just drilled a small hole and attached earth wire. Doing it that way you use the cameras original cable and as some are 5 v it is sensible to do so or you could cook the camera.
I would never "cut into" a circuit in a VW
Do it the proper and safe way Tigs dont look nice smoking on the side of the road
