Originally Posted by
Simonr23
i tried the reset procedure, mentioned above. i dont think it worked, as a didnt hear any strange noises.
just seems like in 20000kms time, i'm going to be here complaining about how my clutch is shuddering, when it was 'self' inflicted(by the car) if any manula car was driven the way this thing does the 1st-2nd change, the clutch would be stuffed in no time.
never mind how it behaves under TJA mode in peak-hour traffic... as in 'holy clutch slip batman', type behaviour for a llooonnnggg time each time the car is nearly stopped and as it auto-creeps forward as the cars ahead do the same (most not dsg, or manuals)
I have the same issue with my dq381 7 speed and it is tuned!
In heavy traffic i use the paddles to hold it in 1st gear also do so in the morning coming up my steep driveway
At 37k so far with no issues tho great gearbox otherwise
Also get the tdi tuned i did and it transforms the drive the torque from 2 to 3k is just astounding and it pulls hard all the way to redline if you want
2017 Golf Alltrack 135tdi All options
19 inch Brescia Wheels Golf R brakes front and rear
Calipers painted Candy apple gold
New rear sway bar and linkages
