Page 1 of 9 123 ... LastLast
Results 1 to 10 of 83
Thread: Discover pro screen internal crack?
    Feb 2018
    Loaded android auto this morning and noticed two sharp lines on the screen.
    Was fine last night and only appeared today.
    Haven't had an accident and there is no visible sign of damage to the outside (thought maybe someone might have reversed into it).
    Will be heading to the dealer tomorrow to see if it can be replaced under warranty.
    Can see it in the photo running parallel to the blue line.Discover pro screen internal crack?-20180422_073817-jpg
    Sent from my SM-N950F using Tapatalk
    Feb 2018
    Also, no external crack on the screen when you run your finger over it
    Apr 2014
    The Monash Freeway
    Looks more like a bad connector to me, if it’s exactly one pixel wide.
    Ben
    2015 Polo GTI & 2019 Golf R
    Mar 2017
    Tasmania
    Quote Originally Posted by BenT View Post
    agree with BenT - that is a screen issue, not a crack. That whole panel line is buggered. It happens on lcd screens - early x5 bmws are a good example - screen needs to be replaced. Warranty would likely be a full replacement unit because the soldering/desoldering is not within the skill level of the normal dealership
    Feb 2018
    Quote Originally Posted by doc_777 View Post
    Hope so! Seems like the easiest option is to replace.. will find out tomorrow
    Jul 2010
    Robina Gold Coast
    Is it only when the GPS is turned on . What about the reversing camera mode ?
    Feb 2018
    Quote Originally Posted by ian View Post
    Yep, it's showing on every screen so is not specific to an app or function.
    Took it to the dealer this morning who has said they will have to raise a report to VW before starting work.
    Will keep the post updated as it progresses
    Feb 2017
    Same issue with our Tig. That fine line through the screen appeared yesterday. Only appears when the screen is turned on.
    Looks like a warranty replacement job to me.
    2016 RS3. 2018 RS3 Sedan. 2018 Tiguan Rline
    Yup, ours has it too. We have three single pixel wide strips. Will wait till first service.
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
    Feb 2018
    Sounds like it's becoming a common issue, have noticed some American forums are having the same issue.
