Originally Posted by
cameleon72
I have chance to open play and reasarch on both generation display units in tiguan 2, including the ver 1. with knobs and ver. 2 with full glass display touch panel . The version 2 of discover pro 9.2inch it gives much niceer and more acurate color , better black level and conttas vs ver.1. However the version 2 has some serious issue with overheating ,most likely ips led panel and pcb electronics heating more and large glass like display panel atract more sun from our hot ozi sun which can get extremly hot in less than 30 min in use during sunny day. This ll will trigger inside lcd pannel ribon to pcb to fail and lose contact .The first ver. does not havr this issue at all. Iwould suggest all owners with ver.2 to run display on lowest seetings brightness ,will help lots to reduce overheat . replacment will need to have new version with built in behind fan cooler or better passive radiotor or it will happen again and again in hot areas like we have here in Australia
