Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: Discover Pro 9.2" - does it warn you if you're over the posted speed limit?
    Apr 2012
    Hi all,
    Recently pickup up an MY18 140TDI Highline and had a question about the navigation system. Does the Discover Pro 9.2" warn you if you are over the posted speed limit, or is there a setting to enable this? Have had a good look through the system settings but no luck.
    The reason I ask is because our second car (Mazda CX-3) warns you if you are over the posted speed limit, whether it be a 50, 60, 80, 100km/h speed zone.
    Is what I've described above available with the Pro system?
    I realise that you can set a maximum speed warning.
    Any help much appreciated
    Aug 2016
    Auckland, NZ
    Quote Originally Posted by nickows View Post
    Hi all,
    You will need to turn on Road Sign Recognition via coding which displays the speed signs on the AID. This then give you the option to display a warning if you go over a certain threshold. Have a look at the coding pages on this forum for instructions on how to do it if you have an OBDeleven or VCDS or someone with one.
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
    Apr 2012
    Quote Originally Posted by NZ_GolfR View Post
    Excellent. Thank you for the info. Much appreciated
    Nov 2013
    AUS
    I must not have fully coded it correctly then, mine has TSR but does not tell me I've gone over the limit.
    Will have another look when I have time.
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
    Aug 2016
    Auckland, NZ
    Quote Originally Posted by veew View Post
    There is no specific coding to enable this, just once turned on go into your Car Settings in the Infotainment system and under Driver Assistance there should be settings for the Road Sign Recognition where you can turn the warning on (visual and audio) and at what speed over the detected speed limit you want.
    Nov 2013
    AUS
    Mine only has an option to enable it under the instrument display settings. If you get around to getting a screenshot that would be awesome.
    Current:
    Aug 2016
    Auckland, NZ
    Make sure you have the following option set:
    Information Control Unit (5F) > Adaption > Car_Adaptations_Gen2 > menu_display_road_sign_identification > Activated
    You should then get this:
    May 2017
    Off topic. Does RSR also recognise traffic lights? Even better, does it warn you when the light changes to yellow?
    No
    Nov 2013
    AUS
    That was the missing jigsaw. Works great, thanks muchly!
    Current:
