Page 6 of 6 FirstFirst ... 456
Results 51 to 53 of 53
Thread: Discover Pro 9.2" - does it warn you if you're over the posted speed limit?
  1. #51
    Apr 2018
    Quote Originally Posted by Grugly View Post
    Needs to be coded with obdeleven or vcds.
    Also doesn't work perfectly in Australia but works well enough for standard road signs.
    Thanks Grugly
    Looks like I will need to buy one of these code systems
    Do you know which one is better ?
  2. #52
    Feb 2018
    Quote Originally Posted by FastMitch View Post
    Thanks Grugly
    Vcds is expensive and is used by car workshops etc for diagnostics..
    Obdeleven is more of a consumer tool and depending on your tech comfort level is probably the more affordable option.
    Can get obdeleven through autoinstruct only in Aus.
    Sent from my SM-N950F using Tapatalk
  3. #53
    Adelaide hills, SA
    What he said. Though the OBD11 works only as long as you’re connected to internet, which can be limitation.
