Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 53
Thread: Discover Pro 9.2" - does it warn you if you're over the posted speed limit?
  1. #41
    Jul 2017
    Melbourne, Victoria
    Quote Originally Posted by shanec View Post
    That was great info Bruce
    1) What does MIB stand for ?
    It's the Discover Pro. MIB stands for Modularer Infotainment Baukasten in German which means Modular Infotainment Matrix. MIB II is the 2nd generation of the platform.
    2) Once I have loaded the POI data, does the Highline make an 'audible' alert PRIOR to the speed camera ?
    I don't know how far from the POI it dings (as I haven't tried importing POIs) but you can set POIs to ding when you are near them. Look at the vwgolf forum thread step 4 and see the Annäherung Information tickbox (Annäherung means approaching apparently).
    Tiguan Highline 162TSI | Indium Grey | DAP | MY18
  2. #42
    Dec 2017
    Castle Hill, NSW
    So I tried this out and there are a few things that aren't quite right.
    First, the VW website to create the POI file has moved to: POI-Listen Sammlung < Discover Pro < Volkswagen NAV-Companion < Volkswagen Deutschland
    Second, the file won't load, so there's a workaround here: Custom POI new 9.2&quot; Discover Pro
    Also, the recommended image for the cameras looks like a European one so I created this if you want to use it. BTW, the tool will resize to 39x39 pixels so whatever image you use seems a bit small.
    Discover Pro 9.2&quot; - does it warn you if you're over the posted speed limit?-speedcameras-jpg
  3. #43
    Dec 2017
    Castle Hill, NSW
    Also, you get a funny little ping about 20m before the camera...
  4. #44
    Mar 2018
    Unhappy
    Quote Originally Posted by OZROD View Post
    Thanks Ozrod
    In my 6 year old car I get notifications at least 200m, 100m, 50m then the beep sequence accelerates if I am nearing a speed camera and I am over the speed limit (i.e. slow beeps to rapid beeps)
    This tells the driver that you are about to get snapped if they don't slow down immediately
    20m does not seem like much ... I really can't decelerate from 100km/h to 60km/h in 20m
  5. #45
    Jul 2009
    Don‘t speed in the first place
  6. #46
    Mar 2018
    Quote Originally Posted by mickofoz View Post
    It's not me ... it's the car... it has a mind of its own
    Seriously, is there no way via OMBD11 or VCDS to increase the notification distance of the warning of the Speed Camera POI to be more than 20m ?
  7. #47
    Dec 2017
    Castle Hill, NSW
    I couldn’t find anything. It’s not actually trying to warn about an upcoming camera, more telling you that you’ve arrived at a POI... I looked through the metadata with the POI file and couldn’t see anything so I guess it’s just part of the standard POI program. Maybe it can be changed via OBDC?
  8. #48
    Mar 2018
    Don't know about OBCD, hoping someone can answer this one.
    Wonder why some car companies have systems that warn you well in advance of speed camera but VAG does not ...
    Wonder if it would be easy to create dummy speed camera POI that are 200m, 100m before the actual POI
  9. #49
    Apr 2018
    Quote Originally Posted by NZ_GolfR View Post
    Make sure you have the following option set:
    Information Control Unit (5F) > Adaption > Car_Adaptations_Gen2 > menu_display_road_sign_identification > Activated
    You should then get this:
    I don't see Traffic Sign Recognition in the 2019 Tiguan Highline Discover Pro settings
    Has it been removed ?
  10. #50
    Feb 2018
    Quote Originally Posted by FastMitch View Post
    Needs to be coded with obdeleven or vcds.
    Also doesn't work perfectly in Australia but works well enough for standard road signs.
    Sent from my SM-N950F using Tapatalk
