Results 1 to 10 of 20
Thread: Dealership and obdeleven mod
    Feb 2018
    Blog Entries
    1
    One of the obdeleven mods I have done is DRL off when handbrake is on, I have my tiguan booked in for yearly service and wondering if the mechanic when checking lights for operation is going to think there is a fault.
    Do I be up front and it will get noted on my records or say nothing?
    Has anyone else had this situation and how did you deal with it?
    MY18 Tiguan R Line Black-162 Highline TSI
    Drivers Assistance Package - Sunroof - Tow Bar
    Ordered July 17 Arrived December 17 Delivery Jan 18
    Oct 2015
    You may find that any computer updates they apply (if relevant) reset this option back to factory default. I’ve had this a few times with traffic sign recognition.
    Pacific Paradise QLD
    Quote Originally Posted by Wazza 162 View Post
    Technically doing that is illegal because DRL's are deemed to be a safety feature and it is illegal to disable a safety feature that is built into the car
    Reset it back to normal for the service Easy to do and wont cause a problem Dont know why you want to turn it off but its a nuisance sitting in the garage playing and they are on, i will admit A far better mod is to turn tails on with DRL
    Oct 2018
    Melbourne, VIC
    I can't speak to the fault code which may appear, but they've never cared about any of the cosmetic modifications/DLA/TP i've done through obdeleven.
    Maybe an easy test you can run is to connect the obdeleven dongle to your car and see if any light-related faults appear on the app. If not, you may be in the clear for when they run their diagnostics.
    Quote Originally Posted by PDMJO View Post
    If you have done the mod correctly there wont be any fault codes I did a scan with mine 2 days ago after changing my 6 digit key in the unit and no codes came up and Ive done 17mods
    Dec 2006
    Kilsyth, VIC
    On one hand I wonder if they will even notice?
    On the other if they do they may end up running around in circles trying to work out why things don't work since there are no fault codes. (ie they change the bulb and things still don't work).
    Probably best to mention when dropping it off (or turn the mod off while it's in there).
    You have me wondering, why do you have it setup this way anyway?
    Nov 2016
    MAPLETON Qld
    I’ve done this mod, no problems with dealer and servicing
    Quote Originally Posted by The_Hawk View Post
    Only reason I can think of its easier on the battery if you are sitting with ign on fiddling
    Feb 2018
    Blog Entries
    1
    That's exactly the reason I did it, more worried about them looking for faulty globes etc as someone has mentioned.
    Is it still illegal even though DRL are only off with handbrake on and hence stationary?
    As far as I can ascertain any interference wit a safety feature is. But that works Ok because when H/brake is off lights are on
