Hi Hillbilly and IsDon and thank you for a great info thread.
I have one question that I think I have worked out but not sure as the manual does not cover the use of a second battery to power the DR750S-2CH.
I already have a dual battery set in my Tiguan, to run a fridge, and I am planning on powering the DR750S-2CH from the auxiliary battery, via a relay, which is turned on and off via the ignition circuit ( I am using the rear cig power socket to control the relay ).
When I need to run the DR750S-2CH while parked, I will have a switch to bypass the relay and power the cameras direct from the auxiliary battery.
From what I can get from the manual, this should be a straightforward setup, but would you know if there anything with the wiring or power requirements that I have missed?
