I mounted mine high up on the passenger side just to the left of the sensor box thingo. Yes it's not perfectly centre but it gets everything in view that matters.
Sent from my SM-N950F using Tapatalk
Whatever you guys do, just remember to run the power cabling under the curtain airbag not on top.
I am sure in the event of a deployment, the cable will snap like a toothpick, but I can imagine in the odd even the cable will turn into a great whip lol.
Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
I have thought about the airbags in a lot of cars when wiring cameras over the years... I have had no problem with the fact that the airbags will destroy the flimsy little cables. I don't pull things apart far enough to route under airbags, and I certainly wouldn't be touching airbags regardless!
You can easily remove the pillar trim with a bit of finesse, the highest clip being the most annoying as it's a double locking clip, or "christmas tree" clip as it's called.
Once you've removed the trim/cover you can easily route the cables behind the airbag.
^ that works too, however if you're running a rear camera as well then routing down, back then back up will make it a not so fun task![]()
I fitted my mini 0906 'pair' at the weekend - as stated, the A-pillar trim is awkward (had to re-shape the top clip and it is still not sitting perfectly!). Ran the wiring to the rear camera under the passenger side scuff trim and through to the tailgate grommet - happy with the end result (apart from the slightly dislodged A-pillar trim).
Not so happy with the camera running for twenty minutes and then power-cycling and corrupting the data. Will try a re-flash (firmware update) and see how we go. Image quality looked good!
