Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 52
Thread: Dash Camera Preference
  1. #41
    Pacific Paradise QLD
    Quote Originally Posted by PeteC View Post
    I know, right? It is amazing how many people with or without OCD don't care if the lens is exactly in the middle or not.
    But if we are talking about personal preferences, I don't like your wiring. That would disturb my OCD, seeing those two wires hanging in my view every day. Horses for courses.
    Can be hidden right down to the front of the unit on the screen. Cant see more than 50mm of wiring on mine and cant see it from drivers seat as I showed earlier. I have altered it since reply 32 as have had a new screen in
  2. #42
    I mounted mine high up on the passenger side just to the left of the sensor box thingo. Yes it's not perfectly centre but it gets everything in view that matters.
    Sent from my SM-N950F using Tapatalk
  3. #43
    Apr 2009
    Melbourne, VIC
    Wiring is not in my view every day. And there's no way I was messing with the sensor box just to hide cables that are already of no concern. I'm as OCD as the next OCD person and my install is perfectly fine.
  4. #44
    Quote Originally Posted by Rocket36 View Post
    Wiring is not in my view every day. And there's no way I was messing with the sensor box just to hide cables .
    Ha ha they didnt put the cover back on mine properly when the screen was done and it nearly fell off so did the wires while putting it back The cover actually doesnt fit tight to the screen so is room
  5. #45
    Whatever you guys do, just remember to run the power cabling under the curtain airbag not on top.
    I am sure in the event of a deployment, the cable will snap like a toothpick, but I can imagine in the odd even the cable will turn into a great whip lol.
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
  6. #46
    Apr 2009
    Melbourne, VIC
    I have thought about the airbags in a lot of cars when wiring cameras over the years... I have had no problem with the fact that the airbags will destroy the flimsy little cables. I don't pull things apart far enough to route under airbags, and I certainly wouldn't be touching airbags regardless!
  7. #47
    You can easily remove the pillar trim with a bit of finesse, the highest clip being the most annoying as it's a double locking clip, or "christmas tree" clip as it's called.
    Once you've removed the trim/cover you can easily route the cables behind the airbag.
  8. #48
    Quote Originally Posted by Dose Pipe Sutututu View Post
    You dont even have to do that If you run it along the edge of the dash beside the A pillar and up between the screen and the A pillar the airbag wont get it as it will be infront of it where the wiring goes.
  9. #49
    ^ that works too, however if you're running a rear camera as well then routing down, back then back up will make it a not so fun task
  10. #50
    Aug 2018
    Adelaide Hills
    I fitted my mini 0906 'pair' at the weekend - as stated, the A-pillar trim is awkward (had to re-shape the top clip and it is still not sitting perfectly!). Ran the wiring to the rear camera under the passenger side scuff trim and through to the tailgate grommet - happy with the end result (apart from the slightly dislodged A-pillar trim).
    Not so happy with the camera running for twenty minutes and then power-cycling and corrupting the data. Will try a re-flash (firmware update) and see how we go. Image quality looked good!
