Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 52
Thread: Dash Camera Preference
  1. #21
    Apr 2017
    I have no idea if this is new or not (i assume just arrived in Aus) but Audi has official Dash Cam.
    https://shops.audi.com/en_GB/web/acc...affic-recorder
    Now....why doesn't VW have it
  2. #22
    Adelaide hills, SA
    I guess, the cost might have something to do with it.
  3. #23
    Sep 2011
    Melbourne, Victoria
    Since there are so many cameras around the car, wondering if there is a way to record the video from all these cameras while the car is driving normally, then can get video from all angles around the car.. Then a dash cam is not required.
  4. #24
    Jan 2013
    Hi there!
    If you have a Tiguan MK2 and if you have a Blackvue front dash cam, may I ask where did you mount it?
    In front of the mirror console, or right side, or left side?
    I am planning to mount it in front/bottom of the mirror console but there is an opening on the console and I am afraid that I am going to block something. ??
    Dash Camera Preference-img_2596-jpg
  5. #25
    Apr 2018
    Dash Cam Install Tutorial – Volkswagen MK2 Tiguan – AutoInstruct
    I don't own a Tig but the Art it's similar and I put it in the same spot as the link above.
    This position:
    Allows the cables to tuck in nice
    Ensures easy ability to remove from mount
    Doesn't affect your driving visibility
    Doesn't get in the way of any instruments
    Arteon & T-Roc
  6. #26
    Apr 2018
    My recommendation is not to install it under the mirror/instruments purely from a drivers visibility standpoint.
    Arteon & T-Roc
  7. #27
    Jan 2013
    Quote Originally Posted by HiddenTaco View Post
    Awesome, thanks!
  8. #28
    Jun 2018
    Melbourne,Victoria
    Just make sure you can easily get to the SD card if you want to remove it to copy all the content onto a computer, or swap it over for a long trip if you want to keep the content.
  9. #29
    Sep 2016
    Brisbane, Qld
    Quote Originally Posted by PeteC View Post
    Hi there!
    Hi PeteC,
    Although the AutoInstruct write-up is very good a) it's only for the front camera and b) I wasn't happy with the camera position for two reasons; one being it's too far off centre for my liking and secondly accessing the cables and SD card are a PITA - you need to move it even more to the left to get to them properly. Because of this I decided to mount mine under (behind) the mirror. Below is a very quick write up
    Dash Camera Preference-img_3029-jpg
    From the driver's seat the camera is hidden and the lens is central to the car. As I don't like to see any exposed cables I ran them in the headlining and then hid them in the mirror housing trim so only the minimum is exposed. Had to put a small notch in the cover for the cables though.
    Dash Camera Preference-img_3011-jpg
    For the rear camera I removed the plastic cover trim on the hatch (held on with 5 clips – 3 along the middle and one at each end) and fed the camera cable through with the existing cables. The two ends of the corrugated cable cover simply clip off allowing the cable to be inserted (use solid wire or similar with a draw wire then securely tape on the camera cable and pull through). Feed through the body work and secure along with the existing cables.
    Dash Camera Preference-img_2962-jpg
    Dash Camera Preference-img_2965-jpg
    Dash Camera Preference-img_2968-jpg
    To run to the front I inserted the cable between the plastic trim(s) / door rubbers and the headliner until the A-pillar.
    Dash Camera Preference-img_2974-jpg
    Tiguan 162TSI Highline with DAP in White.
  10. #30
    Pacific Paradise QLD
    Brizzypoms method is by far the best as in the linked one you cant get the power plug out or the card. I'll bang on about my Passat but it will be less obvious in a Tig as you sit higher
    Rear camera is attached to a piece of Colourbond flashing material bent to slide in the rear door roof trim and looks like this Saves having to run the cable into the taildoor and is easily adjusted if you bump it
