Originally Posted by
PeteC
I ended up installing it on the left side as per Autoinstruct.
While I agree that the camera is not exactly in the middle, it is now not in the way of the driver or the passenger and you can easily slide out the unit by pressing the button on the bracket and remove the power cable then remove the card if needed.
The cable gets closer to the headliner to hide and the fixing point of the bracket is behind the darkened windscreen, which makes it less prone to loosen in direct sunlight if it gets too hot.
Never had one fall off in 6 years in temps from -5 to over 40C One thing I was careful not to do was run cables that would be in front of airbags and i question running along near roof when vehicle has curtain airbags. I ran mine along under trims above carpet so no danger.
For front camera along edge of dash and up the A pillar between screen and trim so airbag cant snag it and rip the camera into your face
View of camera from drivers seat 100mm of cable exposed only
