Yes very happy with them. I used to have the suspension in sport all the time as the ride was so floaty in normal or comfort. I now drive most ofnthe time in normal, comfort on low trips or car full of people and boot full and still does not feel as floaty as the stock springs.
Supplied and installed via Peerless
Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
How would anyone know that the springs have been reset? The process is to heat them up to a bit over 1000 degrees, which obviously burns off any paint or markings, compress them to the desired height, retemper them, often also shot peen and then paint. So they look like new springs that no one could tell were reset. So whether its illegal or not is a mute point as no one could possibly prove it one way or the other.
As for cutting, if the springs are parallel then the only evidence is the lack of paint on the end of one coil, which when installed in the car is invisible as it sits in the spring seat. If you are good with a touch up spray can it's invisible. So whether it's illegal or not is again a mute point.
Insurance wise, that depends on your insurance company and applies to any modification you make. If you are concerned, then keep you standard suspension for a quick swap over before the assessor arrives. If they even bother to, most accident repair approvals are done via pictures these days.
Gary
I'll emphasise something from the first post "if done properly", resetting springs requires the right equipment and an experienced operator to use it. For example, get the temperature even slightly wrong and it will no longer be a "spring", as a result it will sag very quickly. So make sure you use someone suitably equipped and qualified.
Gary
