Hi everyone,
Looking to you experts for some informed opinions from you all on cutting vs. resetting aftermarket springs, specifically on aftermarket Eibachs.
Are either of these two options feasible? Is one better than the other?
The average response across various forums is that there seems to be more people wary of cutting springs rather than resetting springs.
I've come across a few websites which state that there's no difference between aftermarket springs before and after the reset, however, this sounds a bit too good to be true.
Going into specifics, the Eibach springs I've got just isn't low enough on the rears, as they currently sit about 20mm higher than the front. Because of that, i'm thinking of lowering the rear springs a further 10mm.
Taking into account another 3mm? of settling, it should end up close enough to even.
As it's only a 10mm drop below its original intended height, would that negate any concerns for the shocks/bottoming out more often?
I'm not fond of coilovers as a solution because I don't want to lose the DCC.
