Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 71
Thread: Coolant warning
smarty Coolant warning 27-09-2017, 12:59 PM
spacemannz I’d top it up as per the... 27-09-2017, 01:14 PM
smarty Yeah I'm booked in for next... 27-09-2017, 02:27 PM
spacemannz I have to admit I lifted the... 27-09-2017, 03:43 PM
smarty Yep mine sits on the same... 27-09-2017, 04:15 PM
ope126 Just grab some G13 and top it... 27-09-2017, 05:25 PM
NW3192 Coolant warning 27-09-2017, 08:37 PM
Bora Sport Just top it up with water.... 27-09-2017, 09:43 PM
smarty I understand the premise on... 27-09-2017, 11:08 PM
Bora Sport I was only suggesting that... 28-09-2017, 06:33 PM
smarty Cheers It’s only come on... 28-09-2017, 11:43 PM
Cobwebs I've done only 4800kms and... 22-10-2017, 06:33 PM
Gashde My coolant warning came up... 27-10-2017, 11:04 AM
IsDon Coolant warning 27-10-2017, 02:35 PM
Gashde Cheers on the info mate!... 27-10-2017, 03:10 PM
IsDon Coolant warning 28-10-2017, 05:28 AM
Cobwebs With my coolant warning... 28-10-2017, 08:28 AM
Gashde Went in yesterday, guy... 29-10-2017, 05:18 PM
Dose Pipe Sutututu Thread bump, my shietbox... 09-04-2019, 06:48 PM
smarty Yep mines done it again and... 09-04-2019, 08:38 PM
smarty Ok so it’s done a a seal on... 12-04-2019, 01:22 PM
Dose Pipe Sutututu Quality car, considering it... 12-04-2019, 09:26 PM
Guest001 My 2 day old one has the... 12-04-2019, 05:58 PM
smarty Yeah but things like this can... 12-04-2019, 10:02 PM
Dose Pipe Sutututu That was their approach on... 17-04-2019, 11:02 AM
cameleon72 With all otherserious issue I... 15-04-2019, 11:32 PM
jolv hi guys, i did not receive... 22-05-2019, 03:14 PM
Guest001 NO you should buy a bottle of... 22-05-2019, 03:58 PM
Transporter You can top up with the... 22-05-2019, 04:25 PM
rave75 My Passat had the coolant... 18-06-2019, 04:54 PM
Transporter Just put distilled water in... 19-06-2019, 04:24 PM
Simonr23 The expansion tank (I’m... 22-05-2019, 04:20 PM
feenix74 Do not use Supercheap Auto... 18-06-2019, 05:11 PM
Guest001 Look on the side of the... 18-06-2019, 05:50 PM
Dan_3MPS Happened on mine as well. Was... 19-06-2019, 02:36 PM
Dan_3MPS Happened again the other day,... 28-09-2019, 11:28 AM
feenix74 My understanding is that you... 19-06-2019, 03:43 PM
rave75 Thanks for the reply guys!... 21-06-2019, 11:57 AM
GRD Coolant warning 21-08-2019, 12:06 PM
sharp Just before my 2... 21-08-2019, 09:15 PM
GRD That's good to know. Thanks. 22-08-2019, 11:09 AM
Tim Foley Coolant consumption 29-08-2019, 07:49 PM
Passat R36 thats not coolant trace 21-08-2019, 01:41 PM
Scratchyratface I had a coolant leak in my TT... 22-08-2019, 08:30 AM
Simonr23 Crock of ****, is my thought. 29-08-2019, 08:45 PM
Dose Pipe Sutututu Sigh, mine has been topped up... 02-10-2019, 06:10 PM
Transporter It’s nothing unusual and once... 03-10-2019, 07:40 AM
Dose Pipe Sutututu But thank you for the 5 year... 03-10-2019, 12:24 PM
Transporter Unreliable? Did it break... 03-10-2019, 01:22 PM
Dose Pipe Sutututu At the rate it's going, I... 03-10-2019, 03:12 PM
Simonr23 Assuming all stories are... 03-10-2019, 02:03 PM
Dose Pipe Sutututu Exactly! If anyone thinks... 03-10-2019, 03:14 PM
Guest001 Yeah wish they would update... 03-10-2019, 06:15 PM
Dose Pipe Sutututu Feel free to add me to your... 03-10-2019, 08:30 PM
Sudoku Now getting coolant warning... 08-01-2020, 06:00 PM
IsDon Coolant warning 09-01-2020, 02:20 AM
Sudoku Thanks mate. Will probably... 09-01-2020, 06:38 AM
Simonr23 To everyone, be careful just... 09-01-2020, 06:16 AM
IsDon Scale builds up when water... 09-01-2020, 06:36 AM
Dose Pipe Sutututu I would only top up with... 09-01-2020, 06:40 AM
IsDon Fill your radiator with harp... 09-01-2020, 07:09 AM
Transporter Haha, very funny! Though,... 09-01-2020, 10:45 AM
Simonr23 I know you mean well and... 09-01-2020, 07:30 AM
smarty Ok so 54k kms coolant light... 17-07-2020, 10:03 AM
Transporter Time for a new water pump... 17-07-2020, 01:41 PM
smarty Apparently not they just rang... 17-07-2020, 02:54 PM
Dose Pipe Sutututu Took them 3x attempts to... 23-07-2020, 11:06 AM
Simonr23 Might be worth your while... 17-07-2020, 06:05 PM
Dose Pipe Sutututu At the 29xxx km service, VW... 23-07-2020, 11:05 AM
smarty car back to fix a gearbox... 02-06-2021, 11:45 AM
notaGolfR Distilled & de-mineralised... 02-06-2021, 03:51 PM
    Aug 2019
    Marleston, SA
    Quote Originally Posted by sharp View Post
    Just before my 2 year/30,000km service I've got the coolant light come up. The water level was just under the line in the reservoir. I thought the dealer would just top it up and send me back home but no, they did a pressure test without asking and found a leak. They replaced the thermostat housing. It's all good now.
    Nov 2018
    Cairns
    Coolant consumption
    My 2016 Passat B8 132 tsi has coolant low warning light come on at 27000 klms. Checked reservoir and it was indeed below minimum. Took to dealer. Was pressure tested no fault found .topped up and issue attributed to air lock from factory. 10000 klms later at minimum level again this time tested again and leak from thermostat housing detected. Housing replaced and VW also replaced water pump as precaution . 10000 klms later again at minimum level. Pressure tested again no fault found and issue attributed to possible air lock when water pump was replaced. Topped up. 10000 klms later again at minimum this time the most ridiculous excuse given and I have this stated on invoice from VW dealership and was repeated from VW Australia. “ coolant consumption up to 500 ml per 1000 klms is within specification. This means your vehicle could consume 7.5 litres of coolant within a service interval and VW would consider that vehicle to be operating within specification. Would you consider such a vehicle fit for purpose? I dont
    Quote Originally Posted by GRD View Post
    Jul 2013
    Hills District
    May 2011
    Yeerongpilly, Brisbane, QLD
    I had a coolant leak in my TT just last week, turned out the Thermostat had a leak (the water pump had already been replaced under warranty). Thermostat & labour cost me $2000, unfortunately out of warranty
    BMW Z4 (2019)
    Audi TT quattro (2015), s-line in Nano Grey - sold
    Oct 2015
    Sigh, mine has been topped up 3x times by the service centre too
    Once when I noticed the issue, 2nd time at it's 15k service and 3rd time when I went into get the bearing/grease fault addressed.
    nek minnit blow pump, and lift a head.
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
    Adelaide hills, SA
    It’s nothing unusual and once it’s out of warranty they happily report it and charge for the repair.
    Many drivers will not even know that there was a leak and it’s been topped up a few times or think that it’s normal to add coolant during the year.
    It isn’t normal, the cooling system is closed to the outside air most of the time and there shouldn’t be any top ups needed. The amount of water that evaporates is negligible and the level should always stay close to the max. If the alarm comes on, there’s a leak.
    But thank you for the 5 year warranty, going to sell it at the 4.5 year mark and buy another Tiguan (MK3 or 4?) and rinse/repeat lol.
    I do like the car, all the creature comforts, but it sure stands up to its name of being unreliable!
    Adelaide hills, SA
    Quote Originally Posted by Dose Pipe Sutututu View Post
    Unreliable?
    Did it break down?
    Did it leave you stranded somewhere?
    Unreliable?
    Did it break down?
    At the rate it's going, I fear it will.
    When you need to bring coolant/distilled water everywhere you go in a car that's less than 1.5 years odd with less than 17500 km on the clock around with you everywhere you go, then labelling it unreliable isn't too far fetched.
    All my previous **** boxes were Japanese cars, never had to do such thing nor have I ever needed to top up the coolant, but yes they also were super boring.
