Originally Posted by
drsmithy
Is a cheapy 18" or 19" rim plus a higher profile (45R19 or 50R1
tyre a reasonable option here ? Any reason not to do that or things to be careful of ? Would a mismatch of tyre width (eg: 235 vs 255) matter that much ?
If I recall the car manual has a warning that speed should be limited to no more than 80kmh when an odd sized wheel/tyre combination is fitted. This would also include an 18" or 19"
Bear in mind that any different sized tyre is NOT going to have the same rolling circumference has the other 3 tyres and will give a warning message on your instrument panel. (the tyre pressure sensing uses the ABS wheel speed sensors and can detect a different rotational speed)
As you are towing, the inherent risks increase in driving and if it is a rear wheel that lets go I suggest you would need to put a full size tyre on the rear axle simply due to the additional load of the caravan. AND still limit speed to no more than 80 kmh until you can get a full size tyre back on the vehicle.
Note I'm very risk aware (in a transport based industry)
In any event I hope you have a safe and enjoyable trip
BeigeJet
White MY23 Tiguan 147 TDI Elegance (mine)
White MY21 Tiguan 147 TDI Elegance (wife)
Gone - Wheat Beige MY07 Jetta TDI manual
