Results 1 to 9 of 9
Thread: Centre Console USB Cubby lighting
    Aug 2018
    I find the I struggle a bit plugging my USB cable into the USB slots in the centre console infant of the gear lever.
    No problems in daylight, but at night or in carparks, it so dark down there that you can't see the USB ports.
    I tend to end up feeling with my fingers until I think I have it lined up, and then plug in my USB cable.
    I am worried that I'll end up scratching around the USB trying to find the hole...insert inappropriate joke
    Just wondering if other have this issue, and whether anyone has a solution to get a bit of light down there?
    2018 Allspace 162TSI R Line
    Mar 2013
    Brisvagas
    Glue a little bit of hair around it?
    Jan 2019
    I just use the flash light on my phone to see at night.
    Sent from my Pixel 3 using Tapatalk
    Pacific Paradise QLD
    I leave a wiggle cord plugged in and just pull that out and plug into phone
    Also bought this which plugs into ciggy socket and gives two more USB with backlighting
    Baseus 30W Quick Charge 4.0 3.0 Car Charger For Samsung Huawei Supercharge SCP USB Type C PD 3.0 Fast Charging Car Phone Charger-in Car Chargers from Cellphones & Telecommunications on Aliexpress.com | Alibaba Group
    Oct 2018
    Melbourne, VIC
    I purchased LED USB lights. I’ve got one in each set of USB ports - it means you can only use one port, but for me it does the trick.
    Mar 2017
    Tasmania
    Yep, leave a cable plugged-in. No reason to unplug it...
    Aug 2018
    Quote Originally Posted by Tob35 View Post
    I use the cubby to store items already so having a cord in there all the time gets messy and in the way.
    I too have a backlit piggy lighter USB adapter, but the light is more outward acing so not very bright in the cubby
    Quote Originally Posted by PDMJO View Post
    Something like this?
    Sounds like a better idea than what I'm using ATM
    Oct 2018
    Melbourne, VIC
    Quote Originally Posted by iDiesel View Post
    Yep. I ended up putting a somewhat opaque plastic book cover (can’t remember what it’s called. Think vinyl wrapping but for books) over the light itself to diffuse it, as I found it too bright. Works a treat
    Aug 2018
    Maybe a bit of black spray paint quickly wiped off to give it a smoky fuller light intensity
