From Brasil
Hi everybody
i just bought a new tiguan RLine 220CV and i did few modification using obdeleven.
The scan found 4 fault after modifications... someone can help me to understand what is wrong or how i can come back to original configuration?
many thanks
OBDeleven data log
Date: 2020-10-23 16:56
VIN: 3VVJ465N8LM127727
Car: Volkswagen Tiguan Allspace R-line
Year: 2020
Body type: SUV
Engine: CXDA 162 kW (220 HP) 2.0 l
Mileage: 71 KM
09 Central Electrics
System description: BCM PQ37BOSCH
Software number: 5Q0937086CE
Software version: 0303
Hardware number: 5Q0937086BQ
Hardware version: 038
Serial number: C86420022002R2
ODX name: EV_BodyContrModul1UDSBosc
ODX version: 020001
Long coding: 00000000000000000000000000000000000000000000000000 0000000000
Subsystems:
System description: 326 LL 200122
Software version: 0373
Hardware version: 034
Serial number: 20011921027060
Long coding: 0E4DDD
System description: RLHSS
Software version: 0207
Hardware version: 051
Serial number: S6Y20M02D05H13M28S20
Long coding: 0008EE
System description: Sensor, DWA
Software version: 0316
Hardware version: 005
Serial number: 000000000ZY200100EZ5
System description: Sirene, DWA
Software version: 0314
Serial number: 00000000000032026401
System description: Lenks.Modul
Software version: 0170
Hardware version: H03
Serial number: 0300140220200C200539
Trouble codes:
U112100 - Databus missing message
static
17 Dashboard
System description: KOMBI
Software number: 3G0920790E
Software version: 4193
Hardware number: 3G0920790E
Hardware version: 503
ODX name: EV_DashBoardVDDMQBA0
ODX version: 001042
Long coding: 00AD2098EE8C00080188734F1001000080000C06
Trouble codes:
static
static
4B Multifunction Module
System description: FCM MQB Low
Software number: 3Q0907338E
Software version: 0367
Hardware number: 3Q0907338E
Hardware version: 003
Serial number: 18022000842265
ODX name: EV_MultiModulContiVW48X
ODX version: 003003
Long coding: 0000000509001DD200104F010A000000000000000000000000 0000000000
Trouble codes:
static
56 Radio
System description: MU-S-N-ER
Software number: 3Q0035864C
Software version: 0876
Hardware number: 3Q0035864C
Hardware version: 853
Serial number:
ODX name: EV_MUStd4CDELP
ODX version: 001001
Long coding: 027306030000000051220002001828001F0506E401200400EF
Subsystems:
System description: ABT_Std-2_Nav
Software version: 8214
Hardware version: 261
Serial number: VWZ6ZMX0236169
System description: MRM1 2020
Software version: 1310
Hardware version: ---
Serial number: --------------------
Trouble codes:
U101400 - Control module incorrectly coded
static
Have you tried clearing the fault codes and seeing if they come back?
This would be the first thing to try.
It may have been that one of your modules had a "brain fart" when you made some changes and this caused the faults. Clear the codes and drive the car for a bit.
yes i tried without result.
now i am doing a new backup and try to compare the differences.
hope to solve..or will be complicate to came back to original configuration
- You may not post replies
- You may not edit your posts
Forum Rules
