Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 65
Thread: Brakes shot at 45k
  1. #51
    Apr 2018
    Quote Originally Posted by iDiesel View Post
    Just replaced my front pads and rotors after the warning light came on.
    Only done 33k.
    And I thought I was driving like Miss Daisy!
    Really the Front Brake Discs are worn at 33,000 km ? That's atrocious !
    Last SUV the original Tyre's, Pads and Discs lasted 80,000 when I sold the car
    This will be the last VW I buy if my Brake Discs need changing at 33,000 km
  2. #52
    Erskineville, NSW
    Quote Originally Posted by FastMitch View Post
    It's all about the driver and where you drive.
    I've got 195,000km on my fronts.
    Rears were done at 155,000km and they probably could have gone another 10,000km.
  3. #53
    Apr 2018
    Thanks, that sounds more like what I am expecting discs should last.
  4. #54
    Its a euro car thing - not VW specific. Harsh brake pads and soft disks + lots of braking in city driving. If you change the pads to a less aggressive pad (eg ceramic) they will last much longer.
  5. #55
    Apr 2018
    That sounds nuts. Pay $60k for a new car to change the brake pads as you get the car delivered because the company puts crap pads & discs.
    If my VW Tiguan Brake Discs only last 33,000 km, seems like I will need to go back to the Koreans where this nonsense is not needed.
    2021 Genesis GV70 revealed: Luxury medium-sized SUV bound for Australia | CarAdvice
    <br>
    279kW/530Nm 3.5-litre twin-turbo petrol V6 (0-100 km/h in 5.1 seconds)
    224kW/422Nm 2.5-litre turbo petrol four-cylinder (0-100 km/h in 6.1 seconds)
    All matched with an eight-speed torque-converter automatic
    In Australian showrooms the first half of 2021
    USA
    RRP $40K
    Attached Thumbnails Attached Thumbnails Brakes shot at 45k-qv70-jpg
  6. #56
    I can understand your frustration, but I believe it is to do with allowing the brakes to operate in very cold climates as well as having good braking performance for high speed (eg Autobahn) driving. We need neither of these features here in Australia, so you spend a few hundred dollars fitting more suitable brake pads and you get longer lasting and less dusty brakes.
    As much as it seems crazy to change the brake pads on a new car, the upfront cost will work out cheaper for you in the long run as you will not be replacing pads and disks after a few years, let alone the money you will save on wheel cleaner sprays.
  7. #57
    Erskineville, NSW
    all matched with an eight-speed torque-converter automatic
    reaches showrooms in Australia in the first half of 2021
    USA
    RRP $40K
    If $300 of pads and rotors is freaking you out then it's best you stay away as you won't like the other costs either.
    The pads and rotors are a Euro thing. They are designed not to squeal and to bite in -30c temperatures and pull the car down from 200kph down to zero several times without waving the white flag. The price for that is lots of dust and regular pad/rotor changes.
  8. #58
    Aug 2018
    I consider myself a pretty docile driver and certainly coast up to lights rather than braking hard at the last minute.
    I learnt the hard way nearly 20 years ago in my first Pajero. Again front brakes @ around 40k
    Big heavy 2.2t driving it like I was driving a Corolla.
    I ended up selling it with 120k on the clock and still on that same set
    2018 Allspace 162TSI R Line
  9. #59
    Apr 2018
    Not about the money, if you know and the car company knows, why does VW not put brake pads that are suitable for Australian conditions at the factory ?
    Sounds like VW know the car is faulty when they are selling it in Oz.
  10. #60
    Pacific Paradise QLD
    Its not faulty It stops and some get far better K's by driving more gently.. Have you got the map installed yet
